Engine wiring harness safety recall (model year 2016–2018)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JosephG, Sep 5, 2018.
Tags:
  1. padroo
    padroo Senior Member
    2,763
    2,253
    If mine showed bare copper and any broken wires I would want the harness replaced. If copper shows but no broken wires I would be OK with liquid electrical tape over the damaged wires and then tape over the repaired area. A sleeve of thick protective material over the whole area would be last.
    The reason I wouldn't want the harness replace would be if it is a complicated process more harm could be done poking around and create more problems than it is worth.
    I don't know if Toyota will give you any choice in the matter.
    mark27lim and UltraJetRefill like this.
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    My harness just has damage in the outer tape, as far as I can tell. I think my local dealer could tape it up but I would not trust them to replace the harness properly.
    #62 Prodigyplace, Sep 10, 2018
    padroo and UltraJetRefill like this.
  3. UltraJetRefill
    156
    93
    Tucson, AZ
    That's my concern as well.
    padroo likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    No - they'll be given parameters which they have to work within.
    padroo likes this.
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    My trusted dealer is 150 miles away but I have never used their service department.
  6. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    I had the J0T recall done yesterday by my facing dealer. Took 45 minutes but they did a 5K as well so no telling how long the recall took.They inspected and taped the area of concern.
    krmcg and UltraJetRefill like this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Called in at my dealers yesterday and they had no clue about it, even though it is showing on the UK's Toyota recall checker. They said they would let me know when they know more. Meanwhile, I have shoved a thin bit of closed cell foam rubber between the wires and the sharp edge of the lid to stop any further damage. Mine just has damage to the insulation tape as it is now, no damage to the wires.
    Prodigyplace and alanclarkeau like this.
  8. JosephG
    JosephG Active Member
    115
    102
    2018 Prius
    That picture looks like it's the woven PET tape. That will be much more abrasion resistant than normal PVC electrical tape so please don't try to do your own repair like I've seen some folks talking about doing. Have a Toyota dealership do it for you with the proper materials.
    The reason the original tape is vinyl is probably because vinyl is fireproof and PET is not. The tape they're using is probably treated with a fireproof adhesive or an additive to the plastic itself, but vinyl the standard for electrical applications.
  9. Elektroingenieur
    2,515
    3,288
    Three Touring
    The remedy instructions (PDF) for this recall, at least for cars sold in the U.S., were posted today on NHTSA’s website. These instructions clarify the location of the possible damage (see page 13) and explain the three possible repairs, depending on the inspection results:
    • If no damage is found, applying Tesa 51036 tape at a specified place;
    • If damage to the harness wrap is found, but after it is removed, no copper or shielded wires are visible, re-wrapping part of the harness with Tesa 51036 tape; or
    • If more serious damage is found, replacing the complete engine wire harness.
    The latter requires draining the engine and inverter coolant and removing the inverter with converter assembly, throttle body, auxiliary battery, windshield wipers and motor, and other parts.
    It’s not discussed in the document, but when developing the remedy, Toyota would have considered that the affected part of the harness includes shielded cables. These can be repaired, of course, but the techniques are not covered in Toyota’s Wire Harness Repair Manual or Electrical Wiring Diagram and may not be among dealers’ expected capabilities.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Interestingly that PDF shows suspect damage area to be underneath the wiring, mine (and others shown in the posts above) has damage on the top, rubbing on the wiring cover.
    mark27lim and Prodigyplace like this.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    Perhaps the covers can damage top and bottom?
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    The bottom bit looks like some sort of bracket (maybe to hold the bottom cover in place ?) and my wiring harness is well clear of that.
  13. padroo
    2,763
    2,253
    I just received my notice for my 10,000 mile check up in the mail yesterday. I don't plan on hitting that mileage until late winter or early spring of next year. If I get my recall notice I will have it done at that time. Hopefully that will be the last time it ever goes back to Toyota.
    I can't afford going in a Toyota dealership because it seems like every time I do I buy a new car. Lol
    krmcg likes this.
  14. mark27lim
    mark27lim Active Member
    108
    104
    singapore
    wow ur right. it actually even goes so far as to say that damage to any other (non bottom) part of the harness should not cause any core wire exposure and does not need to be taped up. ‍♂️
  15. UltraJetRefill
    156
    93
    Tucson, AZ
    Man, 'XI Replace Engine Harness' starting on p.20, does NOT give me warm fuzzies. Thanks for the link though. I guess I'd rather know than not know.
    But, all those torque specs...
    #75 UltraJetRefill, Sep 13, 2018
  16. Mendel Leisk
    42,369
    Oy vey :eek:
    b.Cut a 100mm (3.94”) of the Tessa 51036* tape
    Oh no, not 4": 3.94". :rolleyes:
  17. bisco
    52,891
    duck tape it, and avoid the dealer downtime
    padroo and Mendel Leisk like this.
  18. padroo
    2,763
    2,253
    Surely you recognize that as engineer talk Mendel.:p
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Should be 3.937" to be exact :whistle:
  20. Mendel Leisk
    42,369
    It is my background that ticks me off about conversions. Years back I was starting on a reclaim conveyor (conveyor in a tunnel, under a stockpile) structural layout, and the materials handling (mechanical) department had done an arrangement, indicating that in the tunnel the conveyor was to have a slope of 1.1935 degrees.
    This got me curious, and I wandered around the office for a good half hour, asking everyone involved what was the reason/origin of such an arcane angle. This materials handling arrangement had been around for some time, and no one could remember.
    A structural draftsman happened to overhear, said he recalled it was originally set as 1/4" per foot, and maybe converted to a degree. Yup...:rolleyes:
    padroo and alanclarkeau like this.
