Featured Engine with approx. 100K - increased my Miles per gallon by 13% on
Discussion in 'Fred's House of Pancakes' started by bernie3015, Mar 12, 2022.
  1. bernie3015
    bernie3015 Member
    53
    36
    Los Angles
    Using Sea Foam increased my mpg by 13% from 42.5 approximately to 48. I just used the pre-oil change procedure on the can. For the full story go to Increasing the MPG and the Life of a Gasoline Car with fewer major expenses.
    Also if you have a major oil burn problem there is a more direct approach of applying 100% Sea Foam directly to the rings. This method this is detailed here:
    Burning oil problems due to dirty piston rings (oil & compression) and prevent catalytic converter problems and keep the oil cleaner for a longer engine life
    This method works VERY WELL BUT YOU DO HAVE TO CLEAN OUT THE SPARK PLUG ACCESSES PORTS FIRST OR YOU WILL GET DIRT IN THE ENGINE.
    There is also Sea Foam spray with can be directly sprayed into the air intake. I have not tried that yet. It is easier than than the above.
    #1 bernie3015, Mar 12, 2022
  2. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    97
    34
    117
    lancaster, california
    ... my OEM Gen II ICE was an oil burner. Not necessarily a bad thing. But, my rebuilt ICE is not. I'm seeing about the same average fuel consumption, though under certain circumstance, ex post the rebuild, I'm inexplicably getting 8-12 mpg better, under 30 mph residential driving. After the rebuild, I'm seeing better fuel consumption pulling steep grades, as well - Samuel, '04 Ruthiemobile
