ENGINE WON'T STAY RUNNING
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by LARRY O, Dec 30, 2021.
  1. LARRY O
    LARRY O Junior Member
    New Jersey
    I have Prius V that has 87,000 miles on it and ran great till now. The back hatch door did not close all the way and drained the battery. I pulled the battery and had it charged and tested, After reinstalling the battery I tried to start the car and nothing happened for about 30 sec. then I heard the fuel pump kick in and the car started.I tried to rev up the engine and nothing happened, it ran for a short time and died as if it ran out of gas. Tried to restart it and got nothing. Let it sit for a while restarted the engine and no throttle response and acted like It was running out of gas. Put more gas in over a half tank and started it up and same results. Hit the start button there's a 30-45 sec delay hear the pump run and it starts, runs for a few minutes then dies Has anyone have some suggestions of what the problem could be. As I stated it ran great before the battery went dead.
    Thanks
    Larry
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,718
    Texas Hill Country
    Of course the engine is designed to shutoff after it warms up. Original battery? Have you checked the 12v dc with a meter? A severely discharged and old battery can drag down the 12v such that odd things occur. You could remove it and have it load tested at an auto supply. Finally, it often takes a couple of tries to Ready the car after the 12v has been discharged or disconnected.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,470
    1,516
    NJ-USA
    First thought is that the throttle body needs to be cleaned. With normal engine operation, oil vapors condense on surfaces inside the intake manifold and throttle. Over time that oily film bakes into a carbon sludge inside the throttle bore right where the butterfly valve blade is when closed.
    This restricts airflow some, but the ECM can compensate and adapt by opening the throttle just a little more at idle to keep the engine speed up. The ECM stores this adaptation data in special memory. When you disconnect the 12V battery, that memory is cleared and the ECM resets adaptations to "new from the factory" presets.
    If the throttle does have a build up of goo then it can't flow enough air when it's at the factory values, so the engine can't run correctly- if at all.
  4. gromittoo
    gromittoo Active Member
    718
    286
    philadelphia
    2013 Prius v wagon
    This is "normal" if you have not installed an Oil Catch Can. Overfilling the oil even a tiny bit would make such sludge worse.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    With my Prius, the engine will NOT rev up if it is in PARK, maybe Neutral too.
    Then just because your battery "tested good" once does not necessarily mean that it IS good.
    It still may not be fully charged either.
    Charging it correctly would take several hours.
    If a shop said they did it in 10 minutes.......they lied.
    If the battery is over 5 years old, just get a new one......and check the OTHER end of the main cable connections too.
    After installation, check the charging voltage while the car is running (READY).
  6. ChapmanF
    15,630
    Mine will increase the engine RPM some if you press the go pedal in park. Just up to a sort of moderate RPM.
    Being throttle-by-wire, of course it doesn't feel much like revving a conventional car. It's very obviously a case written into the computer code for "hmm, driver is pressing go pedal in park. Humor him and increase the RPM a bit."
    I have used it to reach operating temp faster after coolant changes, and in the water pump experiments, so it's not completely a useless party trick.
  7. rjparker
    7,979
    4,718
    Texas Hill Country
    March 2019 post
    The op has started four threads since 2019 and has never responded to anyone's replies.
    fotomoto likes this.
  8. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    The ICE isn’t running. Those :30sec “run” periods are the HV battery trying to start the ICE by spinning it rapidly so it sounds like it is running. Too many more of these failed starts will drain the HV battery beyond its minimum charge (that’s a very bad thing).
    How long have you owned this vehicle? Previous history?
  9. ChapmanF
    15,630
    So, it gives us an excuse to yak among ourselves, and maybe something interesting comes out for somebody who reads it later.
    Air_Boss and JohnPrius3005 like this.
