Enginer 2kw kit installed today
Discussion in 'Prius PHEV Plug-In Modifications' started by 2007-Prius-hybrid, Aug 23, 2010.
  1. 2007-Prius-hybrid
    2007-Prius-hybrid New Member
    132
    NY
    I have some questions.. the instructions were lacking..
    How do I know when the battery is charged? Do I leave the main breaker on when charging/not in use? How long does it take?
    The green indicator light on the dash means ready. What does the red one mean? Empty?
    and how many volts should the battery be at when fully charged?
    What do all the LEDs mean on the BMS unit... AND
    How do I attach the vent hose, and has anyone left it off without any trouble/overheating?
    Thanks!!!
  2. overlap
    overlap Junior Member
    56
    Seattle
    Congrats. BTW, do you have Thunder Sky or Mot Cell batteries? Will be interesting to hear about your experiences. Owners do different things and I may be more cautious. I get uncomfortable when an individual cell voltage climbs above 3.4v because the voltage climbs much faster beyond this point for the amount of current input into the cell. (Volt meters have some variability between them too.) I like to see my charged pack voltage up to 54.3v while no individual cell exceeding 3.4v and then the charger taper off to shutdown.
  3. JeffreyDV
    JeffreyDV New Member
    81
    New Milford, NJ
    I did not hook up the blue vent and have not have had any heat issues.
  4. 2007-Prius-hybrid
    132
    NY
    I dont know on the batteries.. (brand)
    How do you tell?
    On the vent- Did you re-install the storage box or leave it empty?
  5. 2007-Prius-hybrid
    132
    NY
    I didn't get a bumper plug with my kit..jack says it ships separate from wholesale marine? Did this happen with anyone else?
    Mike
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    Battery will stop charging when it is full. You do not need to mess with the breaker
    Red comes on when your Enginer pack is low. I shut the system off at this point. You'll wan to charge back up the Enginer pack before turning the system on again.
    Voltage for the entire pack would be around 54-56 V or so. Individual cells ~3.4 or 3.5V
  7. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Thundersky batteries are yellow and fairly large. Mottcells are grey and smaller.
  8. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    Sadly, I wrote them a new instruction guide for the Gen-1 install (Yes, I know this is a Gen-2 you have) and it was 100 times better than the one they had. I took the trouble to generate 3-D diagrams and re-write the "Chinglish" into English, and took very clear and sharp photos of the various parts of the install. They put it up on their website for a few weeks and then replaced it with the old, crappy one again. I had planned to make them a new one for the Gen-2 also, but I guess they didn't want it.
    I never figured out where that was supposed to go, so I never attached it. But that was also in the winter time. I don't have an enginer kit currently (although I've had a new one on order for quite some time and haven't received it) so I'm not sure how the Summer heat would affect that.
  9. ericbecky
    4,369
    3,217
    Madison, Wisconsin
    adric22,
    I'd be interested in seeing that Gen-1 guide if you still have it around anywhere.
  10. JeffreyDV
    81
    New Milford, NJ
    I reinstalled the storage box after some slight modification.
