English Teacher Twists OEM Stiffening Plate w/ Bare Hands, Installs BT Stiffening Plate...
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Free One, Apr 21, 2007.
  1. Free One
    Free One New Member
    After reading all the arguments in this forum I decided to try installing the BT Stiffening Plate, since it seemed logical that a truly stiff member of the car's body (so to speak... B) ) would improve handling.
    I've only got 1200 miles on my Prius, but after a week of wrestling with the car in crosswinds as I drove up I-5 I decided it would be worth a shot.
    Anyhow, I jacked up the car this morning and unbolted the old one. Just for jollies, I tried twisting it with my hands. Now, I'm not the strongest guy, but I could definitely torque it back and forth enough to see a visible twist. It wasn't much, but if I could twist it that much with my hands, I wondered how much use it would be going around a fast corner or coming down our potholed hills around here. Not much, it seemed to me.
    I didn't even try doing that with the BT plate. Are you kidding? I just bolted in on and torqued it to the right amount.
    After doing this little experiment, it seemed immediately obvious that a really rigid plate would be a huge improvement over the OEM one. I can't imagine why people even argue about it.
    I'll report back after the next day of crosswinds though to say how it worked in real driving.
    P
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Enjoy your plate purchase! I look forward to your followup of the driving experience! I'm sure there will be a few more reviews on the plate now that there's currently a sale on them.
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(Free One @ Apr 21 2007, 12:57 PM) [snapback]427354[/snapback]</div>
    Every guy should have a stiff member. B)
  4. BT Tech
    BT Tech New Member
    885
    South Florida
    Thank you for your purchase of our BT Tech stiffening plate!! Please report back your impressions once you have a chance to evaluate it.
    <div class='quotetop'>QUOTE(Free One @ Apr 21 2007, 01:57 PM) [snapback]427354[/snapback]</div>
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    A quick look at the OEM stiffening plate and how it mounts will tell you it wasn't designed to resist torsion. The stiffening plate serves as a tie member to hold the sides of the center channel together, which produces a tensile load. Try pulling the OEM stiffening plate and see how that goes; you will find it is plenty strong in that mode. The affected portion of the underbody is not heavily loaded in torsion. Even if it were, a heavier plate would not help with the existing OEM mounting holes. You would need a larger flange and contact area to transfer a torsion load.
    Tom
  6. Free One
    Free One New Member
    <div class='quotetop'>QUOTE(qbee42 @ Apr 21 2007, 08:31 PM) [snapback]427598[/snapback]</div>
    That sounds logical. I'm surprised that this is the first time I've read this particular analysis after reading a number of posts. It might have made me reconsider. It makes me wonder what kind of forces would pull the center channel apart - it makes the body sound kind of flimsy!
    I'm also curious about the number of people who report significant improvement in cross-wind handling and on cornering after installing the BT plate - what other kinds of forces could account for it?
    Could there be a front-to-back shifting stress (the two sides moving forward or backward in relationship to each other) under the stress of cornering or dealing with side-winds that might account for the reported benefits of it? Or an up-and-down one? Perhaps it's not just torsional stress that's a problem, and the heavier BT plate lessens it, even if Toyota thought that they only needed to be concerned about expansion or contraction of the center channel.
    I suppose what's needed is some objective performance data, rather than the static tests and theory-based discussions we've been having in the forum.
    Anyone have some connections at Car and Driver who could get them to do a before-and-after skidpad test to see if the "g" number changes? Or would even that be an appropriate or objective test?
    I'll see how my cross-wind commute is affected, since that's the main test that matters to me!
    The debate continues...
    P
  7. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(JimN @ Apr 21 2007, 08:05 PM) [snapback]427585[/snapback]</div>
    What do you think is cheaper? Buy the BTTech Plate for the sale price $145? Or get some little blue pills for the factory plate?
  8. Rest
    Rest Active Member
    1,210
    53
    CA
    $145...does that include shipped? If it does then this product has my interest.
  9. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(NoMoShocks @ Apr 21 2007, 09:11 PM) [snapback]427631[/snapback]</div>
    Well, blue pills per pill are a lot cheaper, but if you have to give it another everyday. Forget it.
    Dave M.
  10. AJMasterson
    AJMasterson New Member
    48
    <div class='quotetop'>QUOTE(Rest @ Apr 22 2007, 01:40 AM) [snapback]427693[/snapback]</div>
    I just ordered one last night and it did include shipping.
  11. Tideland Prius
    16,123
    <div class='quotetop'>QUOTE(Presto @ Apr 21 2007, 01:36 PM) [snapback]427403[/snapback]</div>
    no pun intended? :lol:
  12. priussoris
    priussoris New Member
    1,005
    <div class='quotetop'>QUOTE(Rest @ Apr 22 2007, 12:40 AM) [snapback]427693[/snapback]</div>
    I agree it's a stiff price shipping should be included, I too then would have interest in getting one
