Enjoy the A/C in a heat wave
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jul 24, 2017.
  1. bwilson4web
    15,524
    During our most recent heat wave, I have been using the remote activated A/C in both our Prius Prime (via key fob) and BMW i3-REx via iPhone App. I enjoy the irony of how our efficient, low-carbon cars help us deal with the consequences of global warming.
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Yesterday, I ran the A/C while plugged in to monitor how much grid verses battery consumption took place.
    Seeing that have such a minor impact to immediately available range was exciting. Keeping the car cool in the summer and warm in the winter while making a quick stop at the grocery store is a nice perk.
    priuscatprimeguy likes this.
  3. JonW
    JonW Member
    55
    65
    Texas, USA
    I've noticed when I turn on the Climate from my phone while the car is still plugged in it stops charging and uses the battery to run the AC for 10 minutes then takes an additional 20 minutes to re-charge the battery back up to 100%. Anyway, when you are in 100 degree weather with a heat index reaching 110 and it's over 120 inside your car that climate prep is necessary. Sure that 10 minutes only gets it cabin temp down to the low 100s but it's better than 120.
  4. john1701a
    12,755
    5,245
    57
    That's the expectation for 120-volt connections, but not I observed yesterday with the 240-volt.
    #4 john1701a, Jul 24, 2017
    JonW likes this.
  5. DavidA
    2,328
    1,812
    Chicago western burbs
    I open the windows before it charges at-not-100 degrees at night. But that's me, and the weather here -- and, and, and I haven't yet figured out how to get the AC to turn on and cool it down when charging. Baby steps. The good news is that I'm getting well over 30+ miles in EV so far, and 15 minutes could save me 15% on my auto insurance.
    priuscatprimeguy and lx.josh like this.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Yeah, ok. I have AAA and tried to switch to Geico. turns out Geico doesn't give quotes online. You have to request a paper requisition, then after filling that out and mailing it back to them they notify you online what your payment will be. long story short after going through that circus Geico was twice what I'm currently paying AAA.
    Prius from Dad likes this.
  7. bisco
    49,504
    55 degrees here.:barefoot:
  8. priuscatprimeguy
    2,730
    2,640
    damn, there goes the (neighborhood) er EV range:mad:
    bisco and Prius from Dad like this.
  9. john1701a
    12,755
    5,245
    57
    Just tried the test on a second charger.
    With my charger at home (JuiceBox 40 Pro), the grid draw took place while the A/C was running.
    With the ChargePoint station at work, the grid draw didn't begin until after the A/C had finished.
    In both cases, I started with full battery-pack. The difference I noticed was 3.6 kW verses 3.1 kW. (Home provides more power.)
    Anyone know what the A/C draw on max is ?
  10. bwilson4web
    15,524
    The rates are right:
    • 211 VAC - commercial high voltage because they take two legs of three phase
    • 240 VAC - home high voltage because of the split legs transformer
    Measuring the A/C load in the middle of a heat wave, I could park the car in 90F, sunny alley, roll down the windows and plug-in. Driving over in HV mode, I could preserve the SOC so the initial charge is close to 100% so topping the battery would be pretty quick. While plugged in, I can set the A/C to max and use the key fob to enable A/C the monitor the JuiceBox metrics.
