Entune and Weather Location
Discussion in 'Prime Audio, Electronics, and Infotainment' started by VTBIGDOG, Jul 26, 2018.
  1. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    When I press the voice button and say 'Show forecast'. I get a listing for Cornwall, Ontario which is 120 miles away as the crow flies from my location. Anyone had any similar experiences in this area and know how to rectify it? There are numerous HD signals within 20 miles of my location.
    Thank you
    49,498
    of course, it's entune!:p
  3. VTBIGDOG
    211
    146
    That's helpful for sure.
  4. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    try running the entune app on your phone and setting it to prefer phone data over hd
  5. VTBIGDOG
    211
    146
    There is no way to perform the setting you mention above on a '17 Prius Prime Premium. What I did do was to turn on Location on my phone and then launch Entune. I then pressed the Start button and waited for a few minutes.
    I then said 'Show forecast' and the local weather map showed up. I shut the car off, then turned off location and Entune on my phone, waited 20 minuted and 'Started' the car again and the local weather appeared.
    So for now it is working. I know when I travel down South it always shows me the local forecast no matter where I am. Maybe it just got confused.
  6. SteveMucc
    391
    268
    Kentucky
    check out the Data Services setting (page 148) in the manual. You can select between HD, and HD & Entune. True, you can't set it to prefer Entune, but I was hoping that if you allow it to use entune than it may be able to get a closer location than what's available via the HD radio channels
  7. VTBIGDOG
    211
    146
    Finally got a chance to test this. With Entune running it will show the same location 120 miles away no matter how the switch above is set.
  8. VTBIGDOG
    211
    146
    Follow-up...it will show the local weather, but o e you shut off the car it reverts back to the distant location
  9. SteveMucc
    391
    268
    Kentucky
    well.... don't know what to say about that...
  10. VTBIGDOG
    211
    146
    I have a buddy who is a Toyota Salesperson. I contacted him and we are going to try to replicate it on a couple new cars.
  11. SteveMucc
    391
    268
    Kentucky
    keep us posted if you don't mind.
