EPA proposed E15 rule: comment period extended
Discussion in 'Fred's House of Pancakes' started by richard schumacher, May 16, 2009.
  1. richard schumacher
    7,663
    1,039
    United States
  2. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    Here in Minnesota, we are working toward E20. All I've ever used in my Prius for the past 8.5 years has been E10.
    Of course, Minnesota is still pushing research. The source & refinement process had been proceeding well for over a decade before the whole spread to the rest of the country hype. We were the test bed and intended to remain that way for the next few stages.
    2013 is when the E20 mandate here begins. Heavy testing of the 20% blend has been underway for awhile already.
  3. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I recall a specific recommendation by Toyota about ethanol blends, but can't remember what the maximum was: 10? 20?
  4. john1701a
    12,760
    5,246
    57
    There is no recommendation. They simply don't endorse higher than a 10-percent blend. Doing that requires a financial obligation.
    Biodiesel is in the same situation. Automakers are only required to support 5-percent, so they don't bother with anything higher. Of course, biodiesel carries contaminants (gyclerin). Ethanol is the exact opposite, being a cleanser instead.
  5. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Sorry, I guess I remembered it incorrectly. I recall something strongly worded, not to use over a certain percentage. Whether it was corporate playing CYA, or a genuine threat of engine damage, I don't know.
  6. dogfriend
    7,512
    1,187
    Carmichael, CA
    I believe the issue is damage to the fuel system components (lines, o-rings, etc.) if the fuel system is not designed for the higher percentage of ethanol. My 07 manual says no more than 10% Ethanol.
  7. john1701a
    12,760
    5,246
    57
    Not anymore.
    Concern nowadays is on proper fuel/air mixing and emission control.
