EPA says Series Hybrid Better
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Anonymous, May 1, 2005.
  1. Anonymous
    Anonymous Guest
    NewScientist Magazine, April 30 - May 6, 2005, page 25,
    "EPA patenting a contorl system for a hybrid in which the wheels are driven by the electric motor powered by a battery that the fuel engine keeps charged up." "WO application 2005/032875"
    Toyota gives a pretty good refutation of this idea in their document, link is on PC somewhere, about the THSII system that is used on the Prius
    http://www.newscientist.com/article.ns?id=...=mg18624976.400
    THS_II Part 1.pdf
  2. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Coincidently, I was just wondering about this the other day.
    I.e., instead of having the ICE turning the wheels directly, would it be more efficient to have it instead generate electrical power, which would power an electric motor that turns the wheels.
    I have a hard time seeing how you don't end up losing energy in the process. Once again, the Toyota HSD just seems friggin' brilliant to me -- particularly the power splitter device.
  3. xevious
    xevious New Member
    187
    Oregon
    Part of the elegance of the THS/THSII is that it can operate as a parallel or serial hybrid. It's a hybrid hybrid power train!
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    What the EPA describes sounds like how a diesel-electric locomotive works. There is no direct connection between the motor and the drive wheels, it's all electric.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    there is always losses in either system. Sure you could probably get by with a smaller ICE but there is no free lunch in this world. That same small ICE coupled with a 15 or 20 speed sequential shifting transmission would probably move the car also. Could you sell them on a large scale? Toyota's hybrid system is probably about as good as it gets currently. Nissan and as Ford found out it's one of the best. Sure Ford's hybrid drive is not a Toyota but so close that to avoid lawsuits licenced some of the patents from Toyota. Nissan on the other hand bought the Toyota system. If they ever use it is another thing. Honda already uses the series system. Not like the EPA is describing but it's still a series system.
  6. xevious
    xevious New Member
    187
    Oregon
    Actually, the Honda IMA is a pure parallel hybrid.
  7. richard schumacher
    7,663
    1,038
    United States
    I want what EPA is smokin'. To get the same performance a series drive needs bigger motors and a bigger generator. Toyota's system lets the engine do some work directly and at the same time overcomes the problem of maximum RPM on an electric motor (1). It's brilliant.
    (1) Fuel cell cars may need two motors and a power splitter for the same reason.
  8. Frank Hudon
    4,147
    your correct I keep thinking that since the IMA is sandwitched between the ICE and the tranny it's in series but it's actually used in parallel with the ICE to boost output.
  9. Anonymous
    Anonymous Guest
    The dogma is that the most efficient solution is when an engine is connected directly to the driven wheels, rather than first converting its energy to electricity and then to battery or capacitor and then back to mechanical in a motor to drive the wheels - and this is always used as the main arguement against series hybrids.
    BUT it assumes that all engines are equal - they really aren't. Any engine using a gearbox connected to the wheels has to have a whole load of engineering constraints that must be adhered to including (not an exhaustive list!): driveability, smooth idling, high peak power, torque at low revs, ample responsiveness etc etc.
    These constraints limit engine design horribly - hence the ~25-30% efficiency of most gas engines. Take away these restraints and you can hit 50-55% efficiency no problem with seriously improved emissions to boot. So a series hybrid would just have a different kind of engine to a normal car and could easily reach over 100mpg before even having to plug-in. See here for more. ;)
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    Frank...knowing all you know about how the EPA tests cars for gas mileage and you are surprised by this?? i'm not... its right in line with their backwards, behind the times thinking
    of course, if Toyota had done this method, we would probably have a car that got better gas mileage. tops out at 41 mph and have great torque...
  11. Anonymous
    Anonymous Guest
  12. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(bookrats\";p=\"86175)</div>
    Jeff, you are only about 100 years too late! The original 'hybrid cars' did just that, Google and see for yourself. Very interesting. I'm assuming Toyota engineers know about this too and opted for something better suited to today's drivers and technology. :)
  13. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(bruceha_2000\";p=\"86749)</div>
    Bruce -- you're right! I forgot that the Woods Electric Hybrid worked that way!
    (No wait -- I'm wrong, my bad. The Woods worked like the Prius -- power could be either from electric or gasoline engine.)
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    we also have to remember that Toyota's power splitting device and snergy drive may not be all that easy to duplicate or better.
    remember mercedes tried to do the same thing and was shocked to find out that their system got WORSE gas mileage than their regular car did.
    so the math involved aint that easy to figure out. Toyota may already have the best algorithm possible
  15. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Hey, anyone know/have info on the magnetic clutch that this Woods Hybrid used back in 1917? It sounds fascinating... maybe the great-great-grand father of the power-split device. where's that family tree software?!
  16. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(DaveinOlyWA\";p=\"86781)</div>
    As I remember from the Wired article, a lot of the credit for the Prius' efficiency in this area lies in its software. Considered by many to be the "crown jewels" of the Prius.
  17. Robert Taylor
    Robert Taylor New Member
    451
    Rocket City
    Off this topic but the biodiesel potential is still interesting. In Washington State someone is busy building a plant to make biodiesel fuel.
    Check out the thread about "Peak Oil" posted on this site.
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    in the Peak Oil article Robert mentioned, it states that an unrealistically huge amount of farmland would be required and under todays technology bio diesel has a neg energy ratio...iow, it takes more energy to produce it then we can get out of it.
    the ratio is getting better, but current technology would have to rely on a huge breakthrough... the fact that fertilizer is oil based just aggravates the situation.
    another thing though... not a cure-all but more like the Prius...something to reduce consumption, would be using waste cooking oil and other products that would normally be filling up the landfill. this would produce double benefits. this is also energy intensive but only because of our garbage habits. if we were to put a little effort in to sorting our garbage, it would help immensely
  19. Darwood
    Darwood Senior Member
    5,259
    268
    Man, I get sick of hearing this BS that bio deisel is a net energy loss.
    Those numbers are biased and outdated. They presume that farmers won't become more effiecient, that the resulting products will be shipped all over the country by outdated transportation methods, and the organic farming is an impossibility. The small cost of gas increase in the last 6 months has already changes the math so that it is not a net energy loss.
    Why can't we use hybrid trucks for transport, or electric rail?
    Also, farming in the last 50 years has been a push to bigger farms, bigger tractors, which is highly inefficient and oil intensive. Gas price was not a factor, only how much how fast. Why does a huge corn field need to be harvested in 1 day by a tractor the size of a house?
    Can't a small electric machine on a track system do the job? You could have a solar array surrounded by a rail system that slowly guides the small electric tractor around a track as it plants, then weeds, then cultivates. All organic, no oil. It would be slower and the set up costs would be high, but it once set, it could be oil free crop production, with minimal human intervention.
    Now rerun those numbers on biodeisel.
    Even if biodeisel is a loss now, we should proceed with it so that the infrastructure is there when we really need it, 20, 10, or even 5 years from now. These and other renewable infrastructures need to be built NOW, while we do have somewhat affordable oil to do so. Not after we have a real problem and no oil to produce a solution.
    As for the amount of land, supply and demand will take care of that.
    When the cost per mile of driving a personal car is five times what it is now, fewer people will drive cars, opting to use public rails or bikes. Those that do will drive more efficient vehicles, and for shorter distances.
    So yes, our current usage rates are not feasible in terms of acreage, but the acreage we do have, will dictate the amount of driving that is reasonable. Bad growing season? Prices go up and less people drive.
