EPA to revise EPA estimates -- Hybrids will suffer most?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by prius04, May 12, 2005.
  1. prius04
    prius04 New Member
    1,161
    NorthEast USA
    Apparently the WSJ has an article that was quoted by the web site Treehugger.com.
    You can see a blurb on this change here:
    http://www.treehugger.com/files/2005/05/ep...changing_wa.php
    "......The EPA is considering tests that include agressive driving with speeds up to 80 MPH, and another driving under heat lamps with the air conditioner running full blast......"
    Personally, I don't think it's wise to form standards on cars using the exact way people should not be driving.
  2. kidtwist
    kidtwist New Member
    183
    Yes, driving that way would hurt the Prius's mileage. But if they test all cars that way, imagine how poorly a big hemi-powered SUV will do.
  3. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    I can just see the instructions for the new MPG test...
    Step 23: While talking into the cell phone in your right hand, accelerate to 75 MPH and cut off the rapidly accelerating car in the right-hand lane.
    Avoid a collision by as narrow a margin as possible.
    Step 24: Transfer cell phone to right hand; flip bird to driver you cut off with right hand.
    [hr:500e0f5bbe]
    Frankly, this article sounds like some wishful thinking from the big car drivers at the Wall Street Journal.
  4. rookie
    rookie New Member
    61
    Frisco, TX
    So what - a 22% hit would be what - 47 real life MPG while flooring the Prius (really not what would people be doing the most)? That's BAD??? Let's see - what else out there can do this? Right - another hybrid!
    Would just lead to the car that would actually beat it's EPA numbers fo most part.
    They can't screw up this car with a different EPA test. Real world MPG tracking on this site prove so.
  5. Herb
    Herb New Member
    37
    Crofton, MD
    LOL!! That is awesome.
    There should be seperate instruction sets for people reading books while driving and people applying makeup on the freeway.
    Herb
  6. Darwood
    Darwood Senior Member
    5,259
    268
    I would bet that the drop in EPA estimates will be about the same percentage accross all types of vehicles. It just seems like it hit hybrids harder, since 20% of 60MPG is a lot more than 20% of 15MPG.
    Honestly, I can't see this happening, as the average MPG for the big three will drop the same percentage, in an era when half the country wants higher CAFE standards. Unless, of course, they lower the standards by the same 20%.
  7. Robert Taylor
    Robert Taylor New Member
    451
    Rocket City
    Well, driving at 80 MPH does result in a hit on the fuel economy. Returning from Walt Disney World with three of my children and the luggage in the car, we did three hundred miles in the left lane of I-75 at speeds between 83 and 93 MPH on a hot day with the air compressor running the entire time. We got a car computed 43 MPG.
    City driving in 90 degree heat with the air compressor running full time results in a fuel economy hit of 5 to 8 MPG. It can be avoided by running with the windows down, but cabin comfort suffers. People can't hear you on the phone with the windows down or the blower on high, so the quick solution is to cut the A/C off at the steering wheel, let the car heat while you engage in quick conversation.
  8. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Well, I just got back after a few days off. I took a scenic drive through parts of North West Ontario (North of Minnesota) and most of the roads in this region have a posted 80 km/h speed limit.
    Driving along with the cruise at the posted 80 km/h, the MFD routinely claimed 3.8 L/100km or 74 MPG. The tank MFD average was 4.0 L/100km or 70 MPG.
    FWIW last June I took my former 2000 GMC Sierra along the same exact route, and that was when I got the best tank ever out of that truck: 11.5 L/100km or 24.6 MPG.
    Oh, when Mythbusters did their "windows down or A/C on" test with the Ford Expedition, they got something like 12 MPG at steady test track speed. That's quite a bit lower than what the EPA claims at speed, which is 17 MPG with the 2WD and 5.4 V8.
    I would like to see a large and respected test authority instrument a few vehicles (Prius, regular Honda Civic, Tahoe, Dodge Ram Hemi) and carefully test the fuel economy under steady-state at speeds from 80 km/h up to 120 km/h.
    Unless somebody is willing to disprove most of the laws of physics, it's a simple fact that speed has the biggest influence on fuel economy at highway speeds. The faster you go, the more drag increases, and it increases approaching logarithmic values.
    I've noticed a few large nationwide trucking fleets and LTL fleets have the governor set to 55 MPH or 60 MPH max. They've already studied this issue and have concluded that even if they could legally operate the trucks at 75 MPH, the dramatically increased fuel consumption simply isn't worth it.
    This will go a long way to disputing this bunk about "trip time." If you're gassing up far more frequently, you're not saving any time going faster. A test like that may even support reducing the national speed limit to 55 MPH.
  9. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    governor set to 55 MPH or 60 MPH max? :p The trucks in Missouri and Kansas used to blow past me and I was doing the speed limit at 70 mph.
  10. jayman
    13,439
    640
    Winnipeg Manitoba
  11. Potential Buyer
    Potential Buyer New Member
    287
    I'm in favor of this, because alot of people, such as myself, do drive 80 mph, and the majority of people drive 70-75 in places. For example, there are many highways around the country with speed limits of 70 or 75 mph. If you MPG fanatics want to drive 60mph on these roads, prepare to have your rear end smashed by oncoming traffic (which goes 75-90 often).
  12. baeckknit
    baeckknit New Member
    <<Oh, when Mythbusters did their "windows down or A/C on" test with the Ford Expedition, they got something like 12 MPG at steady test track speed. That's quite a bit lower than what the EPA claims at speed, which is 17 MPG with the 2WD and 5.4 V8.>>
    I saw that ep too, but I wondered how true it was to real life driving. When I am driving, once my car gets cooler, I don't keep my A/C on high anymore--I just get too cold!
    babs in Lebanon PA
  13. Russ Yost
    Russ Yost New Member
    65
    Phoenix AZ
    I think AC gas consumption shouldn't be combined with mpg, because it should be given in hours of AC operation (under some standard conditions) per gallon. Such a rating would be useful info for us here in Phoenix!
    The Prius ought to come out well in such a rating, because the compressor is driven by a separate electric motor - the gas engine being used to charge the battery, which it can do at high efficiency RPM, vs the usual arrangement of driving the compressor by the gas engine at various RPM's, including idling (low efficiency) a lot of the time (in traffic).
    The auto climate control system should minimize gas consumption by its scaling back blower speeds after the desired cabin temp is reachedl.
  14. Tideland Prius
    16,127
    I'm still a believer of using A/C over windows down. For one thing, I hate wind blowing at my face at any speed above 30km/h (hence my love for the moonroof). Also, they tested at a lower speed... 40mph if I remembered correctly. That's not highway speed.
