Errant seat belt alarm
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Will B, Apr 20, 2024.
  1. Will B
    Will B Active Member
    390
    343
    Denver
    2023 Prius Prime
    XSE Premium
    All:
    Starting yesterday I get a seat belt alarm for the middle seat in the back. With no-one in the back at all or or with a person in the passenger side and belted, I get the alarm saying that there is a person in the middle seat and they are not wearing the seat belt.
    The temporary workaround is simple, I'm just plugging in the middle seat belt to silence the alarm, but clearly the middle seat "butt sensor" isn't working--ugh.
    Any suggestions on something to try before lugging it to the dealer? They are a pain to deal with, so hoping there is a smart suggestion that could avoid the trip. Might be another reason to get the maintenance manuals.
    will
  2. Jabog6
    Jabog6 Junior Member
    29
    CT
    2024 Prius Prime
    SE
    Mine did that once because one of my kids undid the belt while the car was in motion. (Nobody was actually sitting in that seat - long story). Even after I stopped on the side of the road, put it in park, etc, the beeping did not stop. I clicked it back up, the beeping stopped and I went on. Like you, I also thought the sensor was defective. After I got to my destination, turned the car off, and undid the belt before the next drive, and everything is back to normal.
    Bottom line: the car really did not like having the belt undone while driving, and even stopping on the side of the road didn’t help. Maybe you did a similar thing?
    Will B likes this.
  3. HacksawMark
    HacksawMark Active Member
    439
    287
    Oregon
    2023 Prius Prime
    XSE
    I experienced a middle rear seat alarm a while back. In-laws were riding in the rear and mother-n-law put her purse on the middle seat which caused the alarm.
    Did you have anything on the rear seats when it happened?
  4. Will B
    390
    343
    Denver
    2023 Prius Prime
    XSE Premium
    @Jabog6 : ooh, that may be the case, I did try removing the belt after moving. I will try again with a completely clean start. THANKS! Here's hoping that is the issue. I will report back.
    Will
    Jabog6 likes this.
  5. BiomedO1
    BiomedO1 Senior Member
    1,440
    787
    SacTown, Ca
    It's probably what's known as a "latched alarm". Alarm won't stop unless issue is rectified and acknowledged or next power down, power up cycle. The power down cycle will reset everything and repole sensors status.
  6. Will B
    390
    343
    Denver
    2023 Prius Prime
    XSE Premium
    @Jabog6 was right! It was a 'memory" issue! For the first alarm my passenger likely put some pressure on the middle seat. For the second alarm the belt was attached when I shifted into drive and I removed the belt while just stopped by the side of the road while still on "D".
    Yay, saved a dealer visit, thanks! What happened to the simpler days when the alarm was simply butt sensed and no belt without all this memory stuff? I suppose it is better? But certainly not intuitive.
    Will
    Jabog6 likes this.
