Error code C1A50 out of nowhere - brake master cylinder
Discussion in 'Gen 4 Prius Technical Discussion' started by Elle Puckett, Nov 4, 2024.
  1. Elle Puckett
    Elle Puckett New Member
    los angeles
    I drive a 2017 Fourth generation Prius 2.
    I was sitting in park when out of no where, error messages began flashing on my screen. One after another
    “Antilock braking alert”
    “pre-collision malfunction”
    “breaking power low”
    “antilock brake system malfunction”
    “lane departure alert malfunction”
    “pre-collision system malfunction”
    “ICS malfunction”
    I took it to a Toyota dealership mechanic and they told me they came up with error code C1A50 and that the brake master cylinder needs to be replaced. They quoted me around $3000.
    The car is technically drivable but the brake is spongey. I can’t help but feel like this is a computer error and that I’m getting scammed. How is it possible that my car went from perfectly drivable to broken and needing 3k in repairs?? From sitting in park. My insurance doesn’t cover any mechanical malfunction so I’m hoping someone on the internet has some insight.
  2. FuelMiser
    FuelMiser Senior Member
    1,330
    916
    Monument, CO
    if you "google" spongy brake pedal, you see common causes are 1) air in the brake lines, 2) low brake fluid. Recommended action: brake fluid flush. I would take it to another repair shop for a second opinion.
    Other things to check would be your battery health. You said you were in Park, so the car was ON and the car was powered by the traction battery. Sometimes a weak battery can throw a lot of codes/lights.
  3. Elle Puckett
    los angeles
    thank you for the suggestion! will flush the breaks, unfortunately I already tried switching out the battery and it didn’t solve anything. x
    50,788
    how many miles on her?
  5. bisco
    50,788
    i think you need another dealer:
    search
  6. sorka
    sorka Active Member
    1,017
    197
    Merced, CA
    2019 Prius
    What was the outcome of this? I have the EXACT same error messages starting tonight. It first stared with PKSB Pre-Collison failure see dealer.
    About an hour later, all the rest of the messages in your list started up. Initially, when I only had the first error LDW continued to work just fine but that too has now stopped with the LDW malfunction message.
