Error code P0351 etc
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paolo.rapana, Oct 30, 2020.
  1. paolo.rapana
    paolo.rapana Junior Member
    22
    17
    Torino, TO
    Ciao ho anche il problema di avviare il motore
    Abito in Italia e la mia è una Prius del 12/2009 con 155.000 miglia
    I codici di errore sono P0351-P0352-P0353-P0354-P3190-P3191
    Ho portato la macchina alla Toyota e loro diagnosticato malfunzionamento ECU motore
    so che hanno svuotato il serbatoio e trovato benzina sporca ora sostituita con benzina pulita, hanno sostituito le candele ma la macchina non
    si è avviata Dicono che sia sicuramente la centralina motore
    Ora essendo molto costosa ho parcheggiato l'auto all'esterno la concessionaria ed io rimuovo la centralina per comprarne una usata e copiare i file
    Il numero è 89661-47280
    Secondo voi questa è la diagnosi corretta?
  2. paolo.rapana
    22
    17
    Torino, TO
    Adding ..... I replaced the engine control unit, the engine started, it was running for about 3 minutes and then it jumped and stopped.
    I made a diagnosis and the codes are the same as P0351-P0352-P0353-P0354-P3190 but this time there is no P3191 code
    I do not know what to do
    Does anyone have any suggestions?
    Thanks
    Regards
    49,373
    your first post wasn't translated, but i'm wondering if whatever fried the ecu the first and second time is what you should be focusing on.
  4. paolo.rapana
    22
    17
    Torino, TO
    this is the first untranslated post
    Hi I also have the problem of starting the engine
    I live in Italy and mine is a 12/2009 Prius with 155,000 miles
    The error codes are P0351-P0352-P0353-P0354-P3190-P3191
    I took the car to Toyota and their engine ECU diagnosed malfunction
    so that they emptied the tank and found dirty gasoline now replaced with clean gasoline, they replaced the spark plugs but the car didn't
    has started They say it is definitely the engine control unit
    Now very expensive I parked outside the dealership and I remove the ECU to buy a used one and copy the files
    The number is 89661-47280
    Do you think this is the correct diagnosis?
    I suspect that the engine consumes oil, it wets the spark plugs and the engine dies
    Whoever cloned the engine control unit to me said that they did not find worn or burnt contacts on the original one
  5. paolo.rapana
    22
    17
    Torino, TO
    This evening I went to the dealership and together with the mechanic we tried to start the car.
    the car started there was for only a moment that a cylinder did not start but then the whole engine started spinning for seconds after which the revs dropped suddenly and then stopped
    with the teachstream the codes were p351 p352 p353 p354 p3091
    the mechanic keeps saying that it is the engine control unit to be replaced
    but I replaced it with a used one and nothing has changed
    The mechanic replaced the egr valve, throttle body, fuel pump spark plugs, and then reassembled the original
  6. paolo.rapana
    22
    17
    Torino, TO
    this video is from april and shows a slight smokiness that disappeared when the engine was hot ..... if that helps
  7. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    When you look at the dipstick to check the motor oil, what do you see? Does the oil have a cloudy appearance or is it clear? Head gasket failure is a common issue with these early Gen 3 cars. I believe a leak down test is the recommended way of determining whether or not your head gasket is OK. If any of the cylinders fail to hold compression, you are probably going to need to replace the entire engine, hopefully with another low mileage one from a wrecker. (In most cases, the labor involved in replacing the head gasket and resurfacing the head on your current engine makes that uneconomic, especially since you cannot be sure there is no lower end damage to your engine from running a mixture of oil and coolant). The leak down test is fairly inexpensive and provides useful information even if the head gasket is not your main problem. Hopefully everything works out for you one way or the other.
  8. paolo.rapana
    22
    17
    Torino, TO
    All in all, the oil is clean even if it needs to be replaced
    The car consumes oil it is true, about half a kilo per 5000 km, but as regards the cylinder head gasket there is no lowering of the water level and no oil pollution
  9. paolo.rapana
    22
    17
    Torino, TO
    Today I tried the ignition again and got a torque report when the car has been running for about 30 seconds
    Report freeze frames generato da Torque per Android
    VIN Veicolo:Non presente
    Produttore Veicolo:Sconosciuto
    ID Calibrazione veicolo:Non presente
    Informazioni freeze frames:
    Fuel Status = 0 bytes
    Motor load = 100%
    Engine coolant temperature = 14 ° C
    Fuel correction
    Bank 1 Short Term = 15.625%
    Fuel correction
    bank 1 Long Term = 0%
    Intake manifold pressure = 91 kpa
    Engine revolutions = 776.5 rpm
    Speed (OBD) = 0 km / h
    Injection advance = 3 °
    Intake manifold temperature = 11 ° C
    Air mass flow rate = 6.37 g / s
    Throttle position (Manifold) = 20.784%
    Time elapsed from engine start = 29 s
    O2 Sensor Equivalence Ratio = 1.233
    Commanded EGR = 0%
    Distance traveled by code cancellation = 0 km
    Barometric pressure
    (from the vehicle) = 101 kpa
    (alternative) = 1.233
    Catalyst temperature
    (Bank 1, Sensor 1) = 182.8 ° C
    (Bank 1, Sensor 2) = 62.8 ° C
    Voltage (Control Module) = 14.785V
    Motor load (Absolute) = 45.882%
    Commanded Equivalence Ratio (lambda) = 1
    Relative throttle position = 2.745%
    Absolute throttle position = 53.725%
  10. ChapmanF
    15,435
    P0351 to P0354 are codes indicating an electrical issue, a confirmation pulse from the ignition coil is not being received by the ECU. They also came up in this other recent thread where there is also a link to a Repair Manual section on troubleshooting the cause of the code. It may be useful to have access to an oscilloscope to watch what happens with the IGTn and IGF pulses.
    paolo.rapana and davecook89t like this.
  11. paolo.rapana
    22
    17
    Torino, TO
    thanks, very important information after i read that in some occasions it is enough just for one coil to give the wrong signal to the ecu which can turn out to be all 4 coils fault
    Tomorrow the car will be checked by an auto electrician
    thanks
    tacopyro likes this.
  12. paolo.rapana
    22
    17
    Torino, TO
    Hello, I update you on the response of the electrician:
    For him it is either the relay group 82641-71010 or the power management unit 8961-47100 that creates the problem
    Now I have replaced the realys group but the problem is still waiting for the power management unit
    Anyone know what this is for? Relay Integration 82641-47040 and relay R7 90987-02025 I think these elements are also related to the problem?
    Regards
    #12 paolo.rapana, Nov 22, 2020
  13. paolo.rapana
    22
    17
    Torino, TO
    good evening
    Today I mounted the power management control unit and the car did not go into READY
    so I did a scan of the ECU and there were no errors
    I reassembled the old power management control unit and the car started
    question
    Should the control unit be coded with the number of vin or not?
    PSS likes this.
  14. paolo.rapana
    22
    17
    Torino, TO
    Update
    I changed the electrician, and the result was seen .. He replaced the white control unit of the integrated relays and the car started and no longer presented the errors ....)))) that I have seen up to now
    It has new errors concerning the gearbox lock C2304 C2305 C2306 and they do not reset
    Now let's have the holidays and then we'll solve this too and then finally after 2 1/2 months I'll get my car back
    regards
  15. tacopyro
    tacopyro Member
    82
    Los Angeles
    Happy Holidays!
    is 82641-47030 a european specific part or for 2010s? i'm not certain.
    My 2012 has a 82641-47090 (integration relay #1) which is supposedly current or latest version for gen3 / ZVW30 here.
    you can check the code by following this. just be careful.
    i'm having similar issues with P035* but probably caused by something else... mine looks to be a overheated blown fake ignition coil installed by the PO, but i cant test since i found out about the coil after i took the engine apart.
  16. paolo.rapana
    22
    17
    Torino, TO
    Thanks Tacopyro I have read the page and tomorrow I will show it to the electrician.
    I think component 82641-47030 is specific for year of production and not for sales market but actually I don't know what controls that component
    The component I replaced is used I hope you are not causing new problems because I have never had problems on the gearbox but only on the engine
    Let us know when you have repaired your Prius what was the cause of the anomaly
    regards
  17. Mendel Leisk
    38,646
    Type his name thus:
    @tacopyro
    and he will get an alert. :)
    paolo.rapana likes this.
  18. paolo.rapana
    22
    17
    Torino, TO
  19. tacopyro
    tacopyro Member
    82
    Los Angeles
    it will be a while. parts still on order and i can only work on it on weekends.
    I will update when i find out.
  20. paolo.rapana
    22
    17
    Torino, TO
    REPAIRED REPAIRED REPAIRED
    The nightmare that lasted 80 days is finally over
    After the Toyota dealership and an auto electrician who were unable to repair the Prius, the third electrician in just 20 days was able to revive a car that has now become useless.
    In summary, the problem was:
    Car in motion, the thermal engine turned well when started and after ten seconds the number of revolutions lowered and turned off
    Warning lights on: Engine warning light, Pcs, Yellow triangle and the item Check the hybrid system appeared
    Solution: Replacement of integrated relay unit 82641-47031
    and cleaning from oxidation of the masses in the engine compartment
    My compliments go to the electrician who stubbornly worked hard and solved the problem
    Cost: 1100 euros for the difficulty of finding the defect
    I hope my post will be useful to anyone who will read it
    Best wishes and happy new year to you all
    ZodKod and tacopyro like this.
