Error code problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vanne, Apr 23, 2016.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    C1344 hydraulics system
    Hi all this is the code was display after check what does the problem is ? Please help
    On the screen board was show ABS,VSC, (!), and BREAK ,
    THANK YOU
  2. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    The code points toward either a leak in the hydraulic system for the rear brakes or a bad actuator. And if you have rear disc brakes it could be a problem with a disc. I first would check the physical condition of the brakes, then look in to replacing the actuator which is quite expensive. Good luck.
    Edit: Here's a thread about DIY: Brake Actuator Replacement | PriusChat
    #2 andrewclaus, Apr 23, 2016
  3. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Learn to use the search function w/in Prius Chat or an Internet search engine (Goolge, Yahoo, MSN, etc).
    Many times, the help you seek (especially with a known error code) has already been asked and fixed.
    You should get the factory service manual from Toyota's TIS (Tecnical Information System). https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti?_nfpb=true&_pageLabel=ti_home_page
    It has all the codes and the trouble shooting you would have to go through, electrical diagrams, and more. Way more and a lot better information than Haynes/Chilton repair books.
    $15USD for a 2 business day subscription; the site will likely require a USA billing address and credit card. Hopefully you have family/friends in the US.
