Error Code Question
Discussion in 'Gen 2 Prius Technical Discussion' started by nyconrad, Nov 7, 2007.
  1. nyconrad
    nyconrad Cconrad in Virginia
    222
    Powhatan, Va
    I received this from a visitor to our LIPOG.org website:
    "Kees'
    I did a search in the Prius manual and could not find these codes. Any help for this fellow Prius owner?
  2. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Sorry, double post. Please see next post.
  3. vincent1449p
    894
    332
    Singapore
    [attachmentid=12388]
    58-42 refers to Map Disc Error - Data cannot be read for a specified time due to scratches or dirt on disc surface or insertion of music CD. Inspect disc and replace if necessary. Visually check disc surface and wipe it with soft cloth.
    [attachmentid=12387]
    01-DE 178-F6-2 refers to Slave Reset (Momentary Interruption) - After engine is started, slave component was disconnected from system. Check harness for power supply of component shown by auxiliary code. Check harness for communication system of component shown by auxiliary code.
    01 - Logical Address (Communication control)
    DE - DTC
    178 - Physical Address (Navigation ECU)
    F6 - Connection Confirmation Number
    2 - Number of occurrence
    The slave component in this case is the NAV ECU. Unless the occurrence keeps increasing, there is nothing to worry about.
