Error codes P3030 and P3000 after not driving the car for a while. How screwed am I?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NoTrueScotsman, Aug 24, 2021.
  1. NoTrueScotsman
    NoTrueScotsman New Member
    Melbourne
    i-Tech
    The car was not driven for quite some time so it's possible the hybrid battery went flat and/or some corrosion happened because of that.
    I've successfully torn down the battery and replaced a cell once before, then drove it for years, but it was a massive job and I dread doing it again.
    How screwed am I here? What are my options? Is there any way to manually charge the hybrid battery from nearly empty + would that even help? Any insight into what those problem codes mean? nWaHQMwG4bwo0FtYsSWHp9BuDorgxnHXLhdcmJy6ut4.jpg
    SM-G973F ?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Sounds like one of the voltage sensing wires that attach to each block has cracked, causing an open in that individual monitor circuit. It should still allow the car to function normally.
  3. NoTrueScotsman
    Melbourne
    i-Tech
    Oh the car won't move, it has the red triangle :(
    SM-G973F ?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,047
    1,974
    NJ-USA
    You would want to look at data from the battery ecu to figure out what's going on. As stated it is most likely a fault with the small "voltage sense" wires that connect the HV battery "blocks" (pairs of modules) to the ecu, or it could be corrosion damage to the connector or ecu connectors pins for the sense wires.
    srysoldout likes this.
