error codes
Discussion in 'Gen 2 Prius Main Forum' started by Richard Bjerke, Oct 8, 2019.
  1. Richard Bjerke
    Richard Bjerke Junior Member
    16
    How do I get the Hybrid Control ECU code to display on a 2009 Prius? Is there a place where I can learn how to display all the different error codes?
  2. Frijjj
    Frijjj Member
    60
    35
    Runcorn, UK
    Obd2 port scanner.
    The port is under the stearing wheel under the ev mode button bit by the peddles.
    Ebay do toyota techstream and a usb obd2 cable as a bundle or you can get Bluetooth obd2 plugs but check compatibility with torque pro app
    49,571
    try searching 'blink codes'
  4. ChapmanF
    15,755
    I don't think there are any for the Hybrid ECU.
  5. PriusCamper
    PriusCamper Senior Member
    11,119
    4,527
    Pacific Northwest, USA
    Oh geez... The communication in this thread is so far off the rails before it has even gotten started. Run away, run away, run away.... This thread is not safe for logic and reason yet!
