error P0A0D after rebuild.. saftey plug seated correctly, other codes present
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Mar 29, 2018.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    replaced 4 mods today and after reinstalling I got the following codes, car will not go into ready, I clear the codes with tech stream they come back immediately... this morning before the rebuild the car turned on and moved (very slowly) under its own power.. now I got this..I have reseated the safety plug at least 7 times being sure its pushed in and the handle is pressed down until it clicks.. I tried the safety plug from my parts HV pack and it does the same..
    P0A0D
    P3000
    P3004
    P0AC0
    P0AFA
    c1259
    c1310
    b1412
  2. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    I know nothing about this issue or if this would cause it, but is there any chance you installed a module backwards?
  3. JC91006
    16,482
    8,400
    1. Checked that you've actually grounded the battery pack, bolt it down to the car's body.
    2. The orange disconnect, slide it up and down a few times. I've heard of this error happening and sliding it up and down a few times usually helps fix the problem.
    Athos likes this.
  4. Beachbummm
    1,160
    392
    I checked all are correct thanks
  5. Beachbummm
    1,160
    392
    Ill double check the bolts but Im pretty sure I tightened them all down..
    Ill try sliding the safety plug a few more times..cant hurt
    Thanks
  6. Beachbummm
    1,160
    392
    do you think the car barely moving under its own power is a sign of a larger problem?
    as I posted the other day I wasn't sure if it was the CVT or the moduals... still not sure
  7. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    grounded the battery pack, ?????
  8. JC91006
    16,482
    8,400
    If it goes into limp mode, it won't have much power. I'm thinking the hv battery is causing your issues
  9. JC91006
    16,482
    8,400
    Yes it sounds strange, that pack needs to be grounded to work. If you don't bolt it down, it won't work
  10. Andyprius1
    2,327
    859
    Cool CA
    An electrical ground to the body frame ?
  11. JC91006
    16,482
    8,400
    I really don't know how to explain it, just know if it's not bolted down to the metal, it doesn't work
    Beachbummm likes this.
  12. Andyprius1
    2,327
    859
    Cool CA
    I’m guessing a physical support connection. Never an elec ground from the HV. 500 Volts to ground? A grand fire.
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    The HV battery CASE is bolted to the body of the car. Therefore, the CASE is grounded to the car body, just like the 12v negative. The HV components are NOT. The wire shielding inside the HV cables is electrically connected to the CASE where they enter the relay section of the HV battery, therefore the armor shielding is also grounded.
    Andyprius1 and Beachbummm like this.
  14. TMR-JWAP
    6,229
    5,915
    Columbia, SC
    Any chance the small electrical plug is not connected at the bottom of the safety plug?
    Of the three wires that are connected at the rear left corner of the HV battery, the smallest one is used for the safety disconnect. The receptacle on top turns into a wire that is only a few inches long and merely goes to the lower portion of the safety disconnect where it plugs into another small receptacle.
    The other end of this second receptacle has contacts that are shorted together when the safety disconnect is pushed downward to "click". If that short wire is not plugged in, the system thinks the safety disconnect is not inserted.
    Look at the video in post 2 of this thread. You can see the wire in the first several seconds of the video. Its at the bottom left corner of the disconnect receptacle.
    Red Triangle and P3009-526 | PriusChat
    If it is plugged in, there's always the possibility that one of the pins is bent or something and not making contact.
    #14 TMR-JWAP, Mar 30, 2018
  15. Patrick Wong
    18,200
    6,474
    DTC P0A0D points to a safety interlock problem. Either the orange traction battery interlock has a problem or the inverter cover interlock has a problem.
    DTC P0AC0 points to a problem with the traction battery current sensor, which measures current on the negative traction battery cable.
  16. Beachbummm
    1,160
    392
    thanks, im going to remove the pack again.. the last thing I tried was inserting the orange plug, locked it in place, pushed down until it clicked and jumping that connector with a piece of wire as I thought it might be damaged.. got the same result.. I have rebuilt a few packs never had this issue.. ill bet its something stupid and simple.
  17. Beachbummm
    1,160
    392
    im going to pull it out again and check for corrosion on the connectors.. by negitive cable are they refering to the orange cable that runs to the inverter? they arent marked pos and neg..
  18. TMR-JWAP
    6,229
    5,915
    Columbia, SC
    On the side of the battery pack that has all the voltage sensing wires, the long orange cable at the bottom of the sensor harness is the one that passes through the current sensor and then connects to the battery side of one relay. The opposite end of that cable connects to the negative terminal of the module closest to the battery electronics (module 28). That current sensor also has a small electrical plug about the same size as the one at the safety interlock. Sometimes they just don't fully click into place. You're right, probably worth popping it open and checking every connector.
  19. Patrick Wong
    18,200
    6,474
    The traction battery ECU needs a connection to ground, which probably is via the case.
    1. The traction battery nominal voltage is 201.6V (28 modules * 7.2V)
    2. That voltage is raised up to ~500VAC by the inverter.
    3. It is true that the high voltage is isolated from ground.
  20. Beachbummm
    1,160
    392
    Thanks everyone, the car is fixed...
    I honestly don't know what was wrong.. I transferred all the good mods to my parts case and installed as I did with the original one from the car.. did everything the exact same way so there must be a problem with the wiring in the original battery case somewhere.. it went from the car to the bench replaced 4 mods and back to the car so I have no clue what failed...
    sorry I didn't have to diagnose the cause, Im in the middle of moving and just need it running again.
    SFO likes this.
