Error P0A80
Discussion in 'Gen 2 Prius Technical Discussion' started by fkoali, May 15, 2017.
  1. fkoali
    fkoali New Member
    Jordan
    Dear all
    I have prius 2007 with 230K Kilo meters , yesterday the error above became appear with red triangular , i think its belong to HV battery ?
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Yes, that is a code for a hybrid battery failure. 10+ years is about the time these batteries start to fail (the modules were probably produced in 2005).
    You can replace the failed modules with known good ones, replace with a rebuilt (or used) battery, or get a new one. Each choice has its pro's and con's.
    fkoali, Raytheeagle and M in KC like this.
  3. fkoali
    fkoali New Member
    Jordan
    Thank you for your reply,,i have an old one , but its not worked well , i replace it 2 years a go , can i take a good cells from it and use it in the damaged one ?
    49,432
    to do a decent rebuild, you need to read through some of the threads here. there is a lot of good info on how-to.
    fkoali likes this.
  5. fkoali
    fkoali New Member
    Jordan
    Today i pull up my hv battery out , and measure the cells each one alone , i found that each one is 7.9 - 7.8 volt , except one of them i found it 6.6 volt , i thougt that it was the damaged cell , so i replaced it with one from my old HV Battery which its measure was 7.2 volt , after that i turned the car on and drove it for 5 kilo meters , red triangular and check engine become light a gain , so whatvdo you think a bout ?
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    From what I remember reading, that one out of your old battery was not a close enough voltage match. A grid charger may or may not salvage the battery, but I suspect you'd need to start with a closer voltage match on the bad cell. And then there is the internal resistance to consider.
    fkoali likes this.
  7. fkoali
    fkoali New Member
    Jordan
    The problem solved by replacing one cell 6.5 volt by one of 7.2 volt
    Thanks alot for all.
    jerrymildred likes this.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Be sure the nuts on the modules are tightened to the correct specs.
    And the high voltage cable nuts.
    You don't want anything to come loose or start arcing.
    fkoali, jerrymildred and Raytheeagle like this.
