  1. James mesiano
    James mesiano New Member
    New Jersey
    Replaced high voltage battery a year ago. Green bean battery. A few times in the past year I have gotten P3000 error code. And the car stops and I have to clear the code for it to run correctly again. Then it works well for a while. The car tells me to pull over and get service to the Hybrid system. Any ideas?
  2. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    P3000 could be 5 different things and all of them are covered under GreenBean's warranty. Usually its corrosion build up inside the battery ECU creating inaccurate voltage readings. If for some reason you don't have a warranty it's a simple take pack apart and clean/replace corroded parts job that can be done in less than a day.
