Estimated fuel range.
Discussion in 'Prius c Fuel Economy' started by gbouten, Apr 28, 2013.
  1. gbouten
    gbouten Junior Member
    48
    Alamogordo NM
    I'm not sure if this is the correct section to post this. I have had my Prius C for two weeks now. When the I picked up my car the filled up the fuel tank and as I was going home I noticed it show I had 240 miles of range. I thought this was odd since I was getting an average of 52 MPG. I read that if you don't shut the car down when you fill up it wont reset the fuel level in the tank for this reading. So I filled up but I only put in 2.5 gallons and again the reading didn't change keep going down. In fact we took a long drive to burn some fuel ( and enjoy dinner) and now I have half a tank and it shows I can only go about 100 miles again with an average MPG of 52. Now if I do the math this doesn't compute. So dealer tells me I have to put more gas and that this next fill up should reset it. So if I want to top off my take before I take a trip I have to wait until it has a half of tank? Am I missing something
    51,140
    i don't know about the c, but mine has always reset. however, the least amount of gas i've ever put in is probably 5-6 gallons. you should always shut it off when fueling for safety reasons.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I know that the Gen 2 would not register less than 3 gallons as adding gas. I have no idea what the minimum is on the c. I would let it get to 1/4 tank and try a fillup.
  4. fuzzy1
    10,335
    Don't put too much stock in the miles remaining display. It is just a crude estimate, unconnected to the actual (possibly highly variable) conditions ahead, and has a healthy safety margin built in if the miles ahead are similar to the miles behind. Just ignore it and fill up at any time you wish.
  5. Fauxknight
    Fauxknight Active Member
    210
    116
    My range remaining was off too when I first got the car (5 weeks ago), it gets more accurate as the tank gets lower and with more fill ups...might need a certain amount of data for its estimates. At 50+MPG you should get around 400 miles to the tank and be putting 7 gallons and some change in when you fill up.
  6. Jake123
    Jake123 Junior Member
    74
    35
    I have found the cruising range way off. Usually I have 2-3 gallons left and it reads 0. I always fill it up to a full tank with the car turned off. The pips on the fuel bar are fairly accurate. It seems that the top pip is actually 1.5 gallons and the bottom pip is actually 2 gallons. All the in between are 1 gallon each... or maybe 0.9 gallons to make up for the extra at top and bottom.
    SAronian likes this.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Your dealer "fills" up your tank... the halfway mark stays at halfway from "true" half a tank and sticks there for almost 80 miles (in my experience). The only cases where I ever trust the miles remaining gauge are when I personally fill it to full, the moment it hits half (not later on) and the minute it hits 0 (at this point I know that I have more than a gallon left and to start looking for a station, but that is your option and I don't recommend pushing it if you don't feel comfortable... just know you have miles after 0).
  8. gbouten
    48
    Alamogordo NM
    Ok, thanks I was just wondering what was going on.
  9. gbouten
    48
    Alamogordo NM
    I wonder where it gets it average MPG from? As far as I know there is no MPG number except from trip A or Trip B.
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    You can get an instant MPG and it will actually record the trip from ignition to shut down or as you mentioned trip a and b.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Well, I apologize before hand for somewhat muddying the waters here, because I'm talking about my Prius 2, not a Prius c.
    But I just did my first fill up. When I got the car brand new, a little over 2 weeks ago, the dealership had filled the tank, and the Miles to Empty or cruising range estimate showed 600 miles. Okay, so I drove it until the last pip starting flashing, then pretty quickly refilled. At the time I refilled the miles to empty display showed 29 miles remaining.
    The Prius filled with over 9 gallons. I kept the receipt and marked my mileage down so I can more carefully track it this tank.
    But what I noticed is immediately after filling, when I turned the vehicle on, the miles to empty or cruising range reset, but NOT to 600 miles, it reset to 579.
    It doesn't really matter to me, I'm NOT going to trust the cruising range or miles to empty, and with the extended cruising range of The Prius, I think I'm probably always going to fill up with 2 or 1 SOLID pips remaining, regardless of what the cruising range says I have left. With the pip flashing, the fill was just under 10 gallons, which would suggest I had about 2 gallons remaining....which could be quite a long distance left to drive. But to me? Why push it, and why not enjoy driving further than a normal car, and filling up with less gas?
    But for the life of me, I can't figure out what computerized "logic" is being applied to the cruising range estimate. If the gas station pump is correct (no reason to believe it is not)...then with my Prius's 11.9 gallon capacity tank, I had a good 2 gallons left, even with the pip flashing. So if I had driven even just 1 more gallons worth of the two remaining I would of easily put the cruising range or miles to empty into the negative....
    I've read enough "horror" stories from owners running out of gas, and I have no desire to put My Prius nor myself through anything like that. So I don't really care. I realize the miles to empty or cruising range estimate, is just that, an estimate, but even with a computerized "estimate" there has to be some logic being applied. I can't figure it out.
    As far as I can tell....it's just a distracting number from the actual gas gauge, that you really can't trust for anything. It can make you feel good when you first fill up and see how many 100's of miles it says you can go...but is it really anything more than a feel good, fill up placebo?
  12. gbouten
    48
    Alamogordo NM
    Yea, I got that but what does it use to compute range. It never goes up or down based on MPG just seems to take it's guess and stick with it until the next fill up. Mine last fill up showed 380 miles till empty. That would mean it's guessing I'm going to get 40 mpg.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    It's relatively close... but it will show the same mileage for a few miles. I had 9 miles left for about 15 miles. :)
