Estimated Fuel Range
Discussion in 'Gen 3 Prius Fuel Economy' started by abdullah arslan, Dec 6, 2021.
  1. abdullah arslan
    180
    77
    After replacing 12V battery, the estimated fuel range messed up, it's kinda shifted some amount. I guess, it considered the tank was full when replaced but it was not, so it added up miles. Is there a way to calibrate it?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    I don't think so.
    But it should straighten itself out over the next couple of fillups.
  3. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    It should only take a tank or two to "reset" it.
    With the 12v battery disconnected, it likely cleared all the memory so the computer has nothing
    to reference.
    If you calculate it manual, you'll get a more accurate reading.
    But if you use half a tank, fill up and reset the trip meter, you should notice it more accurate after the 2nd
    fill up ...
  4. abdullah arslan
    180
    77
    Sounds good, I ll check after next fill-up , which is 3rd one
    ASRDogman likes this.
