Estimated monthly electric bill?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by vermouth, May 19, 2019.
  1. vermouth
    vermouth Junior Member
    SoCal
    2024 Prius Prime
    XSE Premium
    The owner of my apartment said that I can plug-in my newly acquired Prius (2014 PiP w/53K miles) to the outlet beside my spot and just add to my rent however much I think it will use per month. He threw out $20 as a ballpark, but I really want to be fair and pay what it costs, since it is pretty great of him to let me do this.
    Does anyone have a rough estimate of how much electricity it would cost to charge my battery full once per day in SoCal (92109)? I am getting a Kill-A-Watt to track it myself, but I imagine it will take a month before I get a better idea.
  2. Salamander_King
    Salamander_King Senior Member
    11,009
    8,934
    New England
    I have PRIME, so my battery is a bit bigger than your PiP, I think about twice bigger IIRC? If you know the actual electricity rate you are paying now, you don't need a month to get the answer. Whatever the rate $/kWh x 3.3 kWh (assuming half of my PRIME full charge) will give you the cost to fully charge yours. If you do this every day, multiply this amount by 30 days. At my local rate $.20/kWh, that would be $.66/day or $19.8/30days. Your electricity rate may vary by time of day, so check that too.
    vermouth likes this.
  3. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    The prius plug in 2014 takes about of 2.5 Kwh of energy, thats from no ev available to fully charged, multiple 2.5 x electricity rate, for example mine being charge once a day x 31 days x the cost of each kwh (2.5 × 31 × 0.073 = $ 5.65)
  4. vermouth
    SoCal
    2024 Prius Prime
    XSE Premium
    Wow, that is a lot cheaper than I expected. Thanks for running the numbers for me.
  5. bisco
    51,140
    huh, all these years, I've been figuring 3.3 kWh plus charging losses
