Featured EV battery charger
Discussion in 'Prime Plug-in Charging' started by Tony Bush, Mar 13, 2022.
  1. Tony Bush
    Tony Bush New Member
    Chicago, Illinois
    Three Touring
    Do I need a dedicated line for the 120v e v battery charger for the 2018 Prius prime hybrid premium?
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    No dedicated circuit is needed, but it should be on a 15 A breaker and if the circuit is shared with other loads, make sure the total does not exceed more than 3A while you are actively charging the car. The car uses 12A max while charging. If you have a smaller 10A breaker or must use more Amp for other electronics, then you have an option of charging your car at 8A by setting the charging amp on your car.
    I use a 120v outlet in a circuit on a 20A breaker, but it is shared with a full-size freezer and several lights and garage door openers. I have not had a breaker trip in the last 5+ years.
  3. BiomedO1
    BiomedO1 Senior Member
    1,476
    797
    SacTown, Ca
    In addition to this, It would be nice to know what else is on the same circuit your plugging the car into - to avoid popping your circuit breakers. This can be accomplished by using a 'fox & hound' circuit tester -
    . This way you'll know what circuit breaker to go after and what appliances to move off of the circuit, when your car is charging.
    49,500
    yes, according to the manual
    Salamander_King likes this.
  5. Salamander_King
    10,975
    8,868
    New England
    It is not required. ONLY RECOMMENDED. While a dedicated circuit would be safer, IMHO, similar to the use of an extension cord, with care, it is fine to use a common circuit shared by other outlets/electronics. I never installed a dedicated circuit. As I stated, I have been using on 20A circuit to outside and garage shared by other outlets with actively connected to several electronics.
    jerrymildred likes this.
