EV battery recharge question
Discussion in 'Prime Technical Discussion' started by yoyoman, Jan 12, 2017.
  1. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    Just wondering if driving a prime in a down hill condition for 1-2hrs, will the depleted EV battery recharge back and get a few miles in pure EV mode?
    iPhone ?
  2. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    Yes.
    49,490
    the more, the better!(y) otoh, there is a larger price to pay getting up the hill. flat is best.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    I consistently get better mileage in the mountains than I do on the flats in my 2004, and not by an insignificant amount (mid 60s, usually in the mountains).
  5. bisco
    49,490
    i'm not that surprised.
  6. yoyoman
    342
    117
    San Jose California
    I will find out this weekends
    iPhone ?
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    1-2 hrs downhill???? What mountain are you descending, Everest?! ;)
  8. yoyoman
    342
    117
    San Jose California
    I was exaggerating- maybe down hill for ~30mi... I may drive from Bay Area to Los Angeles this weekends and will drive into the Grapewine. It's huge mountain that I have to go over before getting into lax.
    iPhone ?
  9. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    make sure you are using DRCC for cruise control so that the car maintains your speed for you, so it will stay in the ECO range better and longer, and maximizing your downhill charging
  10. yoyoman
    342
    117
    San Jose California
    Speaking of better range. Shall I put in hv mode in beginning for driving long distance? Instead of EV Auto for 30 miles and then automatic turn into hv?
    iPhone ?
  11. Trollbait
    11,560
    If you think you can judge when to turn back to EV mode in order to use up the charge before arriving at your destination, then yes.
    Use EV to get to the main route that is the way to your destination. Go Hybrid then, and switch back to EV when you get close to your destination. You could go into EV Auto if you have more charge than you need to cover the distance from the main road/highway to your destination, but this involves more mental work and familiarity with the car's capabilities. Which can be more effort than a person would want to put into a simple drive.
  12. yoyoman
    342
    117
    San Jose California
    I was thinking to use hv in freeway. And then switch to EV auto in local. Should not have too many buttons to press.. :)
    iPhone ?
  13. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    Here in Florida I'm lucky to drive down a hill for 1/4 mile. Sorry can't help you.
  14. Lee Jay
    5,850
    4,024
    This is 51 miles, and about the longest descent I cover.
  15. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    In March of 2009 I drove a 2005 Prius from Newark, Delaware to Corvallis Oregon. Here is the GPS track with altitude:
    The altitude graph with its distance scale was flipped to match the map track. The high points in the center around 1400 miles was leaving Denver and heading over the Rockies. When I got to the western side back to Denver altitude (Grand Junction, CO), my mpg reading was several mpg higher than when I started climbing out of Denver. Engine only on the climb, battery full all the way down. Never did need to use "B" mode.
  16. Lee Jay
    5,850
    4,024
    If you didn't use B mode on the way into Silverthorne after passing through Eisenhower Tunnel, I don't know how you did it. I need B mode and occasional foot braking to keep to the speed limit on that descent. I also use it all the way down Floyd Hill.
  17. Tom_06
    609
    141
    Yah, it surprised me too, but traffic was really flying (March 2009 was warm and dry in a winter of little snow) and I only needed to use brief occasional foot braking. Never had any concern about overheating the brakes. The car still has its original brakes.
  18. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Auto B mode invoked when the battery filled up?
  19. Tom_06
    609
    141
    Didn't seem to. No indication on the shifter display, no obvious increase in engine braking, just a fun coasting at 75 mph with an occasional tap on the brakes. There were plenty of less steep parts where I even had to use the accelerator pedal or have a truck run up my nice person.
  20. Lee Jay
    5,850
    4,024
    If you didn't use either brakes or B-mode down that hill, you'd be over 100mph 1/3 of the way down. If you used brakes, that's not good.
