EV button from Coastletech
Discussion in 'Gen 2 Prius Accessories & Modifications' started by tsunami, Aug 4, 2009.
  1. tsunami
    tsunami Junior Member
    27
    Raleigh
    Not really a button as it uses the cruise control but has anyone installed this?
    Electric Only Mode
    Kirk
  2. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Yes, several have. Two things to consider:
    1) It has a three-second delay to it. I like the immediacy of mine; I don't think I could tolerate the delay.
    2) Coastal's customer service record is spotty at best. When a product is in stock and it works, everything is fine. Backorders, customer follow-up, and technical support ... forget it. There have been reports of the switch failing, with frustration at not getting it resolved. I always suggest that folks considering a Coastal product do a thorough search here to get a good sense of customer services issues before ordering.
    For an inexpensive and relatively easy DIY option see this.
  3. bc104
    bc104 Junior Member
    57
    New York
    I have had it for years and it works flawlessly. Not that I've brought my Prius back to the dealer, but they wouldn't know you had an EV switch unless you told them of they took the dash panels off.
  4. Doc Willie
    1,717
    142
    Out there, somewhere
    I have had three of them and gave up. I put in a separate switch as suggested above, which works better but still not right. Not recommended.
  5. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I installed on and it works ok.
  6. Tideland Prius
    16,155
    installed on my '05 since June 2005. Not issues here. Like JimboK said, their customer service record is pretty poor. Good luck trying to find out order status and such. It will come and they're an honest bunch.. just not very good with customer relations.
  7. avusblue
    avusblue Junior Member
    23
    Saint Paul, Minnesota
    I purchased & installed mine a few weeks ago and like it. It arrived quickly, and works as advertised. It doesn't have much practical use or purpose, but is a fun "parlor trick" to demo to others how the Prius can start up and operate without its gas engine. The piece was very easy to install (about 20 min start to finish, with clear instructions) and is inexpensive. Personally I endorse it.
    Cheers,
    Dave
  8. likesmpg
    likesmpg Junior Member
    49
    Irvine, CA
    Yes, I installed mine 6/22/09 and love it. There are perfect situations for me to use it, so I use it daily. I think it's a great product. No problems here.
