EV Button Installation PDF
Discussion in 'The File Library' started by DaveG, Mar 11, 2004.
  1. DaveG
    DaveG Member
    806
    Vancouver, BC
    As created by Evan - easy to print and take out to your car!
    (see next post for current version)
    Dave.
  2. DaveG
    DaveG Member
    806
    Vancouver, BC
    Updated version - March 13th
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Thanks, Dave, for updating the PDF...I stepped on you a bit on the YG-2G, but that's OK.
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I just installed the switch from Coastal. 1 little detail, the silver passenger side vent cover comes off easier if you push up at the bottom rather than trying to pull straight out.
  5. nvb123
    nvb123 New Member
    FYI, if you don't want to mess with trying to make the female connector to mate with the factory EV button, I found something at Fry's that worked nicely.
    Its a wiring harness for motherboard:
    Motherbrd (sic) Power Supply Extension P8/P9 Kit
    PLU#86800
    F04-207 (not sure what this number is)
    made by GQ, Great Quality (probably in China)
    $6.99 comes with two, so you have spare
    You just have to clip off some plastic alignment guides and snaps, and it fits right in. The friction fit on the metal posts seems to be sufficient to hold it in.
    Regards and good luck,
    Nick
