EV Driving Ratio display
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by M-V, Jun 4, 2015.
  1. M-V
    M-V Junior Member
    Hello got my 2015 PIP in September last year or so. My family member also got one around the same time. But one thing i noticed recently between mine and his is that my kwh and fuel saved by charge always stays at 0 even though i have charged the car a few times. Am I doing something wrong?
  2. M-V
    M-V Junior Member
  3. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    Well it looks like you are running in EV mode only 1% of the time. I'm thinking you do mostly lots of long trips and lots of miles between charges? Does your EV mode come on automatically when you start the car? It should. If yes, do you always turn it off when it comes on?
  4. markabele
    5,084
    1,782
    Nebraska
    How many times have you charged the car? And do you charge it all the way?
    I'm assuming yes based on the ratio screen. And then yes, something in the computer/display is definitely wrong. It should probably read at around 60-90 kwh based on 300 miles.
  5. bisco
    49,408
    300 miles would be at least 20 charges, is that right?
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Sure seems like you're plugging it in but it's not actually charging. Next time you plug it in, press the start button. The graphic should show you how fast you are charging and how long it will take to finish.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    We need more info from O/P before making any judgement.
    The 303 EV miles could comprise of several charges and EV miles collected in downhill driving by switching to EV (when allowed). Those Downhill EV miles make the kWh counter to count down!
    I wonder if we can have a situation of "kWh credit" i.e. negative number, from O/P screenshot I gather that probably not, I have to check it sometime by resetting ratio screen just before or during a long downhill section.
    #7 giora, Jun 5, 2015
  8. M-V
    M-V Junior Member
    Hey everyone thank you for the replys.
    I always charge to full, have charged about 25 times. I don't do any downhill driving.
    To me it just seems weird that it's 0 for everything. I know I'm not the most efficient driver but I'm sure there should be a charge being registered.
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    kWh used counts energy out minus energy in (regeneration) during EV driving.
    Your HV MPG is quite low.
    Are you operating the HV/EV button a lot, toggling between the two?
    Are you constantly monitoring the EV ratio screen or just a glance every long period?
    Your screen is interesting being peculiar, could be a mal-function but could also be a result of your driving habits.
    EDIT - Added
    Those ~25 charges, were they from empty battery? half or more full?
    #9 giora, Jun 5, 2015
  10. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    If you don't mind "losing" the data currently on the screen, you could just reset it, and continue charging & driving like normal and see if it starts working normally. Just hold down the TRIP button for a few seconds to clear it out.
  11. M-V
    M-V Junior Member
    The 25 charges or so have all been from a empty EV battery.
    I dont use the HV-EV button at all.
    I just uses the charge until it runs out then drive like normal
  12. bisco
    49,408
    what does 'ev driving ratio 2' read?
  13. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    What mode do drive in most of the time, Eco, normal, or Power?
  14. bisco
    49,408
    how does that affect the driving ratio screen?
  15. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    In power mode the white EV indicator never lights up, and no EV driving could be calculated as no Gas saved.
    (Edit) Oops, could not find anything to support that Power mode will not allow EV (electric only) driving. So even in power mode there should be some EV driving and fuel savings over that many miles.
    Anybody else notice that the 2015 PiP Fuel saved by charging now has a decimal point. No more reporting 0.99 gallons saved as 0 gallons.
    #15 Chazz8, Jun 6, 2015
  16. bisco
    49,408
    that's a nice addition. did they do the same to fuel used?
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The European version always had one digit decimal on fuel saved by charge and it's liters! fuel used report however is in integers.
  18. bisco
    49,408
    any news o/p?
