EV %, mi/kwh, avg speed
Discussion in 'Prime Fuel Economy & EV Range' started by crewdog, Jan 31, 2017.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Well, here it is the end of January, and wanted to record the following results from the dashboard gauges:
    1486 mi since purchase
    (edit..) 5.1 mi/kwh
    EV range 33.7 after charge
    avg speed while system active 22 mph
    EV driving ratio 93%
    system active time 68:34
    The Entune app for advanced model show mpg up to 999.9, unlike dashboard on vehicle which only goes to 199.9.
    per the app:
    106.41 mi at 999 mpg Nov '16
    523.49 mi at 622.1 mpg Dec '16
    844.38 mi at 401.2 mpg Jan '17
    so far the fuel gauge is down 2 bars, so if I don't make any out of town trips, it may be summer before first fillup.
    #1 crewdog, Jan 31, 2017
    EV-ish, Nic Steussy, inferno and 8 others like this.
  2. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    5.1KWh/mile and 33.7miles per charge don't sound right with a 8.8KWh battery... I'm guessing you mean 5.1 miles/KWh? That would suggest ~6.6KWh of the 8.8KWh battery usable for EV operation, which is probably reasonably plausible: Perhaps 1.2ish KWh in reserve, 6.6ish KWh for EV mode, and 1.0ish KWh for HV operation...
    Anyway, I sure like the 33.7miles per charge! What tire type and pressure?
    We're going to have to follow each other on Twitter so that we can use the ECO Dashboard for bragging rights!
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    That's great! I do think that mr88cet is right about the miles vs kWh, though. My PiP on the first 2 tanks, has gotten 3.82 and 3.84 EV miles/kWh, so if your fraction is upside down, you blew me away! Sounds like you have a perfect driving setup for staying in EV. You might have to drive in HV once in a while to keep the gas from going stale. :D
  4. crewdog
    492
    388
    Woodstock, GA
    Aaack;
    Yes, statistical dyslexia.
    Let me edit that to correct.
    Tires have been at stock psi;
    36 front and 35 rear
    Toyo NanoEnergy A29
    P195/65R15 89S M+S
    I was thinking of going 40 front and 38 rear.
  5. mr88cet
    2,311
    1,334
    Austin, TX
    Ah, P195s just like on my Touring Gen-2... I was guessing the P.Prime uses P185s like the non-Touring Gen-2s. Anyway...
    I'd say you're doing quite impressively with that! 33.7 miles on a charge is pretty awesome!
    I notice you live down South like me. You might be getting better results than our friends up North from not having to fight the cold.
  6. mr88cet
    2,311
    1,334
    Austin, TX
    When my P.Prime comes in ("come home to daddy!"), I'm planning to normally fill up only 2-3 gallons or so per trip, to reduce the chances of gas ... rotting.
    jerrymildred likes this.
  7. bisco
    49,448
    you're having the same problem as me, i filled up on october 7th, still have half a tank. going to florida for 5 weeks in our hycam, might have to burn off some gas intentionally when we get back.
  8. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Bisco, What is your daily/weekly drive distance? Your last fillup was Oct.7 ???
  9. bisco
    49,448
    i retired 2 1/2 years ago, so i only drive 15-20 miles a day, typically all ev. in the summer, when my father is back for florida, it's 100+ miles twice a week.
    so this tank includes a week of that until he left. everything we need is within 20 miles, and when we travel, we take the hycam.
    i've only done 50,000 miles in almost 5 years, and that includes 3 years of a 15 mile r/t commute with charging at work, and various work related travel.
    currently at 32,000 ev and 18,000 hv.
    giora likes this.
  10. Trollbait
    11,544
    Just move it to the Camry.
    EV-ish and bisco like this.
  11. bisco
    49,448
    i'm at 2,000 miles, i have to try and beat my best from june of '14; 2,757 mile tank.:p
    edit: my last fill up was 10/27, not 10/7 as reported in my post above.
    AKCoffee likes this.
  12. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    Really would like to find a calculator that could do a side-by-side comparison. Would like to plug in the following numbers
    Cost per kilowatt hour my utility company is charging me
    my distance I'm able to travel on a charge i.e. my driving habits
    the outcome would provide me amount per mile it's costing me
    The other comparison would be your standard miles per gallon
    cost of gasoline
    distance I'm traveling
    outcome cost per mile in gasoline
    Does anyone know of such a calculator I'm considering trying to make one.
    iskey likes this.
  13. jerrymildred
    11,508
    14,110
    Tampa, FL
    Are you planning to get a Prime, or did you already & just haven't had a chance to update your vehicle information?
    Either way, there is a Google Docs spreadsheet for that here. PIP & MPG Spreadsheet | PriusChat I wanted a little more info, so I downloaded it and added some calculations for cost per 100 miles for my PiP, for a 49 mpg gen 2, and for a regular 28 mpg car. It should get interesting when gas prices head back up.
  14. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    priuscatprimeguy likes this.
  15. bisco
    49,448
    isn't bob wilson doing this over in his prime thread?
  16. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    Prime thread?? new here, I will look for it. or can you send me to it please
  17. bisco
    49,448
    @bwilson4web 'Prius Prime Plus in my hands' you can find it on the first page of the prime forum.
  18. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    The car will tell you lifetime miles per kWh -- call that 'm'
    The utility tells you the pennies per kWh -- call that 'c'
    c/m = pennies per mile
    This calc does not include electricity wasted during charging. That increases your cost some 15%, but it depends on your charger.
  19. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    I'll look at this next time I'm in the car, I don't remember seeing this on the Dash
  20. EV-ish
    602
    278
    SW US
    It is a bit hidden.
    From this display
    Click on the down button on the steering wheel until you reach the data you want.
