EV Mileage Range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Eddie Veloso, Feb 19, 2013.
  1. Eddie Veloso
    Eddie Veloso New Member
    My Plugin is only about 4 months old, but the EV mileage range is now down to 9.8 from 12.4 from the first very first day I charged it overnight. This with HVAC and fan off.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    Mine is hovering around 11 miles in cold weather. It should go back up once it gets warmer.
    The EV range is an estimate based on your previous drivings. So, if you use more electricity per mile, the future estimates will be lower.
    To use less electricity per mile, drive it in slower urban traffic (30-40 mph instead of 60 mph on highway). Use regen brake wisely.... PHV battery can regen only 1/3 of the power when it is near full vs. when it is near depletion toward HV mode.
    Avoid EV-Boost (ICE running in EV mode) as the miles are not counted as EV. That raises electricity consumption per EV mile.
  3. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    Mine started at 12.5 and is now at 10.1. However, I can get about 11.5 miles EV range despite the lower reading on the display.
  4. pip4mike
    pip4mike Junior Member
    Santa Cruz, CA
    I think that this is the latest of perhaps 3 threads on this recurring theme. I've read them with interest because mine dropped from the high 12's initially to about 8.8 miles this winter. I've found that as usbseawolf says its only an estimate, but I've noticed two specific activities that seem to have a great affect on the displayed number. First, I live on a rise with a climb of about 200 feet in only 0.2 mile. This not only causes the issue as others have reported of the ice starting when I start out downhill with a fully charged battery, but the climb in EV mode seems to reduce the calculated range. If I always go to HV mode when making this climb the readout will slowly change over days to the mid 9's after a charge.
    The second factor that I just noticed two days ago is that switching the climate control between Auto and Off makes an approximate 10 to 12% change. So I get to the bottom of the hill and I may have a reading with the heat on of 9.3 miles. By simply pressing the Off button it goes to 10.5. Turning Auto on again drops it back to 9.3, and it does not matter if the ice is running or the car is moving or anything else I've tried. If I only have about 3 miles of EV remaining then toggling the Auto climate control seems to have an affect of about .4 miles. I've also not seen this reported in the other threads.
  5. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    There are lots of threads on this topic. It is all about where and how you drive - lots of stops/starts, hills, flat roads, etc. It all plays into your expected range.
  6. bisco
    49,390
    welcome to priuschat, home of the falling ev mileage, all the best!:cool:
    mmmodem and lensovet like this.
  7. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    You're not alone. Many of us are dreaming what the return of warm weather brings... more EV.
    I was one of the few lucky ones who got a plug-in a year ago, so I've already been through the seasonal cycle. It's pretty sweet watching what higher temperatures bring.
  8. bisco
    49,390
    i can see it picking up miles even in the small swings we've had into the upper 40's.
  9. Eddie Veloso
    Thanks for the replies. I thought I was alone in this issue. I emailed Toyota as well, but I haven't heard anything.
  10. bisco
    49,390
    now that you're here, do a bit of searching in the pip forum and you will find many complaints about this, all with the same answer. like you said, misery loves company.;)
    lensovet likes this.
  11. retired4999
    2,652
    625
    Eau Claire, Wi.
    I think we all new when it got cold EV range was going to drop alot from the cold. We just have to have something to complain about until it warms up! Soon! I hope. :D
  12. bisco
    49,390
    right, plus , it's good to know it's just the cold, and it will return to normal when we do!
  13. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    Single digits today. EV range full charge at 7.5 miles today. Anyone beat that on the low side? Overall MPG still amazing.
  14. nhalber
    nhalber Junior Member
    83
    Marblehead
    Well, I can't complain then. I have gone from 11+ in summer to 8.7 now. Still a mystery.
  15. bisco
    49,390
    do you park outside?
  16. 3PriusMike
    2,963
    2,314
    Silicon Valley
    For you and all others who post their personal EV range numbers it would be useful for these reading (now and in the future) that you provide some kind of context...What are the temperature and weather conditions like (I know you said single digits), what kind of driving (40 mph side streets, 70 mph freeway, a mix, etc.), all EV trips or EV + HV, uphill or downhill or flat, is the heat on, etc. Otherwise all this "data" is a useless as a bunch of thermometer readings without knowing the location and time of day.
    Mike
    RBooker and John Hatchett like this.
  17. John H
    John H Senior Member
    2,208
    558
    Are these just the range estimate or are folks experiencing significant changes in Wh/mile [when cold] ?
    7.5 miles (Big Dude) on a full charge works out to something close to 400Wh/mile.
    The Tesla drivers doing the DC-Boston trip were getting 335Wh/mile (30F) including electric heating, for reference.
  18. 3PriusMike
    2,963
    2,314
    Silicon Valley
    From wall to wheels I'm getting just over 200 wh/mile. My display shows about 13.0 miles on a full charge which calculates out to 208 wh/mile (2700 wh / 13 miles)...this should be the usable battery range number somewhere inside the moving average the PIP computer uses. From Chargepoint I see about 2.9 kwh for a full charge. But then the actual distance I can go is closer to 14 miles not the 13 shown...so 2900/14 = 207 wh/mile.
    Mike
    John Hatchett likes this.
  19. John H
    2,208
    558
    but your not one of the 10F people complaining about loss of range.
    in re-reading my post I should have clarified about the temperature conditions.
  20. RBooker
    RBooker Member
    154
    56
    My EV estimate dropped from 13.4 back in October a low of 8.7 about 10 days ago
    My driving environment
    High temperatures January/February 20-30 degrees
    Commute & errands (<10miles rt)
    90% suburban urban roads (25-45 mph)
    Hills
    Park in unheated garage home & work
    Charge at home & work
    Last week we had a couple of days with highs in the 40s EV inched up to 9.2 cold returned EV back down to 8.8
    EV/HV ratio 67/33
    Computer says 123 mpg
