ev mod with indicator
Discussion in 'Gen 2 Prius Accessories & Modifications' started by priussoris, May 25, 2007.
  1. priussoris
    priussoris New Member
    1,005
    Was just thinking if you had a led in the ev sw that was wired to a positive feed and then the other wire from the led to the pin 27 (grnd) wouldn't that make the led light only when in ev mode then when it is out of ev mode it would break the circuit and led would be off.
    sound feasible?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Nope, it's just a momentary ground that activates EV mode, no signal or anything feeds back from PIN 27.
  3. priussoris
    1,005
    Yeah it sounded too easy... then I thought about it and it is only a 2-3 second hold on my cc stalk to engage it. oh well
