EV mode on gen2, does it strain the system?
Discussion in 'Gen 2 Prius Main Forum' started by Kindke, Jul 25, 2018.
  1. Kindke
    Kindke Member
    London
    Business Ed. Plus
    Im a bit disappointed that my prius doesnt seem to use the battery as much as I reckon it should do.
    When starting up the car, the engine pretty much always comes on initially regardless of outside temp or the charge state of the battery. seems like a waste of fuel.
    There are also times when the only battery is being used when I would of thought that the engine was needed, for example cruising at 35mph on carriageway with light pressing of the accelerator
    And then theres other times when the engine seems to take over when it would seem that the battery would do just fine, for example sometimes 15mph in traffic lightly pressing the accelerator
    One thing I have noticed is that the engine isnt completely off when you take your foot off the accelerator and the engine has been on. It seems like the engine is still ticking over but just not using fuel.
    Then when stopping at lights for sometime, after about 10 seconds I feel the engine shut off completely, and its at this point that the battery will start to do more work, but as soon as the engine comes on again, it feels like using the battery gets shifted down in priority.
    I have thought about using EV mode because I just done agree with the computers choices for when and when not to use the battery but ive read that EV mode should not be used as "it puts strain on the hybrid system and leads to early problems". <- does that have any factual data backing it up or is it just a internet chat meme.
    just to add I get about 58mpg with london driving where my car is.
    52,393
    the prius computers decide when the actors say their lines. there's not much you can do about it.
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,067
    5,306
    Pacific Northwest, USA
    You're driving around a car that was built back when the first iPhones were just starting to come out. If you want to have everything you desire above then you need to buy a brand new plugin Prius prime... Pushing the limits of your 10 year old hybrid battery pack in EV mode will put more strain on it that it can handle.
    As for proof... Well, here in the United States some states adopted a law that required a 150K mile / 240K Kilometer Warranty on the hybrid battery.
    So you know what Toyota did to minimize the cost of replacing bad hybrids under warranty? They eliminated the EV function from all US models. Here in the US you can buy an after market wiring harness to reactivate the EV mode, but as you've mentioned it refuses to work when the engine has to warm up first, as well as in lots of other conditions, not to mention the amount of battery drain on such old and technologically primitive batteries is too much to be practical.
    If you want more proof, go ahead and keep trying to use EV mode too often and watch thousands of pounds vanish from your bank account because you had to repair/replace the hybrid pack.
    SFO, DLC82SV and fotomoto like this.
  4. DMC-5180
    DMC-5180 Active Member
    294
    134
    When I bought my Gen 2 5 years ago I had similar feelings as you. The whole Hybrid thing was totally new to me and was thinking pretty much the same as you. Why can’t I choose EV only mode. As it turned out North American market Prius did not Get the EV only option. However, JDM (Japanese Domestic Market) and I believe EU LHD cars did get the option. I bought the JDM factory switch and installed it per the instructions that came with it. It was from a vendor here on PriusChat.
    At first it seemed pretty cool being able to control EV only. But the reality is after having it on the car for 4.5 years it’s mostly a novelty that I almost never use. About all its good for is parking lot maneuvering or perhaps repositioning your vehicle In a driveway. You can only use the EV mode from a standing stop and the ICE is not running when pressing the button. The EV only mode is speed limited up to 28 mph. At 29 the ICE will start regardless. You might get 1-1.5 miles under very slow driving before the battery level drops to 3 bars. At 3 bars the ICE will start regardless. The NiMH Battery was never meant to be used as an EV only power source.
    Knowing what I know now, I would not bother with it. My Original HV pack has 285k miles and I’m trying to make sure it makes my 300k milestone. I avoid the added stress on the pack.
    iPhone X ?
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You are in one of the newbie phases of hybrid ownership and don't quite understand what's going on.
    The ICE always starts to warmup under light loads (the ev motor is actually supplying most of the motive power unless under heavy throttle or very low battery levels) so it will emit less emissions once it needs to run harder (hard acceleration, high speeds, etc). Once you learn the modes it will make more sense.
    If you don't want to hear the ICE run, like many of us have grow to dislike, get a PHEV or BEV. Problem solved.
  6. DLC82SV
    DLC82SV Member
    241
    119
    It turns on engine initially just to bring the ICE up to operating temp for maximum efficiency on the road.
  7. Bart hall
    Bart hall New Member
    Houston
    How do I purchase this jdm switch? I hyper Mille my Prius as a hobby.
