EV mode only means going to work is pure electric
Discussion in 'Gen 2 Prius Main Forum' started by havanese_boy, Mar 18, 2006.
  1. havanese_boy
    havanese_boy New Member
    Tennessee
    I just finished installing my coastaltech ev mode only mod.
    With their instructions and a printout of a few helpful hints from the forums here, I had it done in 25 minutes and on the first try with only a small scratch on the back of my hand.
    For me this isn't just a gimmick to show friends and family, but a way to get to work and back on pure electric.
    I live in a small town (18k) and driving to work can be done either by a four lane highway or through a few neighborhoods. Granted the drive is only 5 miles...
    I sometimes have to leave work to run errands for the business, so walking to work or riding a bike doesn't work for me and before today, I hated that the Prius would start the engine just to go those 5 miles, when I knew the battery could do it.
    So now I can with the EV mode mod installed.
    Driving through the neighborhood to test out the mod, it was great to not hear anything but the wind blowing.
    The best 50 bucks I ever spent.
  2. darelldd
    6,057
    389
    Northern CA
    Excellent! Now imagine having that feeling ALL the time, on 95% of your vehicle trips. Having a freeway range of 100+ miles on battery alone. Being able to use full acceleration without the engine. Never having to go to a gas station. Never having the oil changed, or the engine tuned up.
    THAT's when we've arrived!
    (that said, driving 5 miles on pure battery in the Prius is going to be pushing it! And you sure aren't getting home on without charging at some point).
  3. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    Yes, let us know how far you get in EV mode. I also use the Coastal EV mod and find that I go from 7 bars (green) to 3 bars (blue) in about 1 mile going 20 to 25 mph on residential streets. That is with 3 stop signs and more uphill than down. My guess is that EV will get you about 2 miles unless you have a lot of downhill.
    - Tom
  4. havanese_boy
    Tennessee
    Ok my trip has 3 stop signs with most of the trip down hill or level. I made it about 2 miles back before the engine kicked in. I never got above 28 mph and was able to coast at that speed for about a mile for part of the trip there.
  5. DaveSheremata
    DaveSheremata New Member
    249
    Arlington, Virginia
    I just installed my EV mod this week too, and I'm blown away. I live about 2 miles from i395, and the cold start in the morning is such a mileage killer. The day that I installed it I did an 19 mile drive and got 59.8 mpg, mixed city nd highway. Knocking out the 25mpg I usually get in the first 5 minutes because of the warmup in "city" streets is a real mileage booster!
    Dave
  6. daniel
    14,487
    1,518
    Spokane, WA
    I've had the EV mod since about fall of 2004. I love it. However, let me warn you that driving long distances in EV mode is probably very inefficient, because in the end the engine must recharge the battery, with all the attendant efficiency losses. Your best use of EV mode is when you can anticipate conditions when the car itself would go electric if it knew what was coming. Things like making head room for re-charging before a downhill, or creep-and-go traffic. Driving all the way to work on electric, and then re-charging on the way home, is likely to be less efficient overall.
    Also, postponing engine start-up until you reach a highway is likely to be inefficient because the car likes to warm up the engine with minimum load and will use the battery more during the first minute or two of warm-up. If you don't let the engine start until you reach high speed, you'll be drawing down the battery faster, always inefficient.
    Enjoy the EV. But remember the basic principle: at high output the engine is more efficient; at low output the electric motor is inefficient; and all electric use must eventually be replaced by the engine, with some efficiency loss.
  7. jeneric
    jeneric New Member
    442
    Redmond, WA
    Yeah, in fact, to me it looks like the ICE has to run almost 3 times as hard to recharge the battery as if it had just been used directly for the power in the first place.
  8. clintd555
    clintd555 New Member
    251
    It'll be nice if you can plug in the battery instead of relying on the ICE to charge it. Then you can really capitalize on the EV mod.
  9. daniel
    14,487
    1,518
    Spokane, WA
    True, a plug-in hybrid would be the ideal solution. But the 2004-2006 Prius is a poor choice for a conversion, because the electric motors are not powerful enough for normal city driving. The speed and acceleration limits are too low. And the present battery is only good for a mile or two, so plugging it in would be utterly pointless without replacing the battery with a much bigger one. Two companies will do that today. But you still have the power limitations in EV mode.
    Cross your fingers for the 2008 (???) Prius to have extended range and bigger MGs with plug-in option. Maybe that's too much to hope for. But I think it's the direction of the future.
  10. le diable
    le diable Junior Member
    Ankeny, IA
    You think thats bad - I made the mistake of moving within a mile of my office... Most of the time the engine never shuts down during the trip, so I average ~30mpg. Once the temp comes up more I'm definitely going to be riding a bicycle as much as the weather will permit.
    At least I can be happy about the fact that I'm still getting better mileage than I would be in my V8 Camaro
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    glad you like your EV mod, it can be very nice and useful in certain situations. however, aint no way you will go 5 miles on EV unless its a major change of elevation.
    what you can do is EV the last part of your trip or EV the short errands you do while at work.
    before i changed shifts, i frequently had to park in one of the alternate lots at work. the farthest one is about a ¼ mile from the primary lot. EV mode in most cases is enough to make this trip, sometimes twice. granted my SOC is not max'ed out. usually at its normal of 60% give or take.
    now what Dave said may not sound like a good idea to some, but realize that at freeway speeds your warm up time is greatly reduced. so if you can EV till you get to the freeway, its true your ICE warm up doesnt start till then, but your warmup should take much less than 5 mins.
    i have also done this method and it does seem to help a lot. problem with me is that my freeway entrance is 1.3 miles away and i only make it on EV less than ½ of the time.
  12. havanese_boy
    Tennessee
    The round trip is 5.4 miles. That is why I said I made it there just fine and part of the way back before it kicked out of EV mode.
    I did it again this morning as my local church is very near my work..the wife thought it was cool also.
    I agree this is nothing compared to having a hymotion battery in the trunk. But it's better than nothing.
  13. darelldd
    6,057
    389
    Northern CA
    Ah, I misunderstood. Thought it was 5.4 each way.
    So in this case, I have a healthier, quieter, cooler and even cheaper alternative. Ride your bike! :)
  14. havanese_boy
    Tennessee
    Nice idea, but often I have to make trips to town (unplanned) and carrying 4 or 5 boxes of copy paper or a trip to wal-mart for supplies makes a bike not an option.
  15. daniel
    14,487
    1,518
    Spokane, WA
    While 30 mpg may sound like poor mileage for a Prius, you are still burning a lot less gas in absolute terms, than other Prius drivers. We get into this mpg bragging-rights contest, who gets the highest mpg, when what really matters to the health of the Earth, is how many total gallons you burn. So your one-mile commute is a lot more effecient, at 30 mpg, than a 5 mile commute at 45 mpg or a 10 mile commute at 60 mpg.
    Good on you for burning less gas!
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    that V8 camaro would have gotten less than 10 mpg... you can bank on that
