EV mode Q: Benefits? Damage?
Discussion in 'Prius v Technical Discussion' started by Slide_into_the_V, May 7, 2018.
Tags:
  1. Slide_into_the_V
    Slide_into_the_V Junior Member
    phoenix, az
    2013 Prius v wagon
    2013 V base model. It's running fine. But I have a question about EV mode-
    Would it cause any extra wear if I were to use EV mode as often as possible? Say, accelerating from intersections? I get that there's a point of diminishing returns, but let's say that the battery is mid-high and the engine is warm. Am I doing any damage?
    Second question- am I actually saving gas if I do this?
    I usually try to stay in EV mode for the first 10-15 MPH, depending on if someone's behind me. I've been averaging about 50 MPG. I like to think that my driving habits are helping.
    I normally don't use the EV mode button, just keep the throttle low enough to stay in EV mode for initial acceleration- but I had this idea today about using EV mode more- but thought maybe there was a wear-based engineering reason that the car doesn't automatically stay in EV mode longer.
  2. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    Limits on torque demanded and maximum MG1/MG2 RPM trigger the switch to ICE. You can achieve what you intend in any of the three drive modes, which just serve to map your right foot position to MG and/or ICE "throttle" position.
    51,141
    1) no, you can't damage the car.
    2) you may be saving a little gas, but don't try keeping it in ev as much as possible, that would waste gas.
    3) be courteous to drivers behind you, as you accelerate slowly.
  4. rjparker
    rjparker Tu Humilde Sirviente
    9,590
    5,889
    Texas Hill Country
    EV mode won't stay on longer because there is not much capacity in these hybrid system batteries. EV mode use won't improve acceleration or do you much good at all since the system will switch to gas very quickly. The "purpose" of EV might be to leave a parking spot quietly, assuming the engine has already warmed up first. In my mind, the only reason to purposely drain the battery might be if you know miles and miles of generally downhill regeneration is likely and you want to prolong regeneration going to the battery. When the battery can't accept more charge and you are still in a regen situation, the car will use engine and friction braking more with no furthe help to your overall mpg. I have even seen the engine come on a stop if the battery is maxed out, I assume to burn off some charge.
  5. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    This is from the owners manual for our Prius v...
    Personally I simply let the car computer figure out the driving mode. It's smarter than I am...:)
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Welcome!
    If you're accelerating gently enough for it to stay in EV on its own, you're saving gas by virtue of the gentle acceleration. If you put it in EV mode and drive that way as long as you can, you're probably wasting gas unless you're about to regenerate by going down a big hill or something like that. As @Sooner Al said, let the computer decide. It knows way more about what's going on inside the engine and drive train than we do.
    You're apparently doing something right, though, because 50 mpg with a v is pretty good.
  7. lostinheadguy
    lostinheadguy Junior Member
    67
    48
    United States
    2013 Prius v wagon
    Under normal circumstances (but especially in Eco mode), if you feather / lightly pulse the throttle in, say, a parking lot or in slow-moving traffic, the computer will probably have you in EV mode anyway.
    Our driveway is narrow and we sometimes have to switch cars around, I engage EV mode to move my car the 30-50 feet so that the engine doesn't have to start.
  8. PriusV17
    PriusV17 Active Member
    327
    167
    CA
    2017 Prius v wagon
    bisco, your profile shows you have a 2012 Prius Plug-in. Your power train should be identical to a regular Prius right? Except you can go up to 60mph in pure EV mode? Can you accelerate from 0 to 60 in pure EV or does gas have to kick in? This would tell me that any Prius is capable of going pure EV if given the right battery and upgrade to be plug-in capable.
    I found out that Chevron bought the rights to nimh battery chemistry and forbid any car maker to give it a plug. They would sue any car maker that does.
    Chevron and EVs – GM, Chevron and CARB killed the sole NiMH EV once, will do so again
  9. PriusV17
    327
    167
    CA
    2017 Prius v wagon
    However, this Reddit post mentions the patent expired in 2014.
  10. Slide_into_the_V
    phoenix, az
    2013 Prius v wagon
    Oh man, this is getting juicy. Also, it confirms any conspiracy theories that say oil companies are trying to suppress fuel economy innovation. *Grabs popcorn*
  11. Tideland Prius
    16,445
    As long as you stay with the ECO area in the Hybrid System Indicator screen, it'll be in EV mode. Once you go into PWR, it kicks the engine in.
