EV % on Prime
Discussion in 'Prime Fuel Economy & EV Range' started by Njner, Aug 17, 2018.
  1. Njner
    Njner Junior Member
    2018 Prius Prime
    It appears that on the PIP one can see what percent of the drive is in EV mode. Is this option available on the Prime and if so how do I see it?
    52,362
    idk where, but you can. just an fyi, with gen 4, toyota has changed ev% to anytime the engine isn't running.
    with the pip, it was wall charge only.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,963
    New England
    EV ratio is displayed on “Drive Monitor” see pg 221 of manual. Edit: the page is for 2017 Prime manual. It may be on different page for 2018 Prime manual, but the operation and display should be the same.
    Drive Monitor Displays information such as the driving time and average vehicle speed, which are linked with the current mileage display. (→P. 198) Current contents of the display Displayed information shows which driving record the currently displayed contents are based on. “Elapsed Time” “Average Speed” “EV Driving Ratio” For the displayed distance of the mileage display, the percent traveled using only electric motor power is displayed. Each time is pressed, the mileage display (→P. 198) switches and the contents of the “Drive monitor” change as follows.
    #3 Salamander_King, Aug 17, 2018
    huskers, Njner, benagi and 2 others like this.
  4. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    Is this helpful?
  5. Salamander_King
    11,024
    8,963
    New England
    Not for the OP's original question. Split screen will not help to find out the percent of the drive in EV mode.
