EV prius button???!!!
Discussion in 'Gen 2 Prius Main Forum' started by thecan, Nov 2, 2005.
  1. thecan
    thecan New Member
    39
    Grabbed this from
    http://toyota.jp/prius
    website.
    What the hell could this button be?? An all EV option?? Would be RAD.
      File size:
      348.1 KB
      878
  2. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Yes, the Asian and European verison of Prius has the EV button. If you do a search on it, you'll find lots of posts about it.
    Basically, if you press that button, you'll operate with only the electric motor for a limited distance under right conditions.
  3. thecan
    thecan New Member
    39
    WOW thats awesome.. sorry about the double posting.. didnt even bother to search I was so intrigued. Too bad the oil corporations dictate whats good for us. Its a shame.
  4. aaf709
    3,862
    2022 Prius Prime
    This site has instructions on how to make your own. Sigma Automotive and Coastal Tech both sell them for about $45.
    Do a search on this, there are Pros and Cons about having it.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
  6. thecan
    thecan New Member
    39
    thanks for the leads guys.. I will def check into it!!
  7. efusco
    19,891
    1,192
    Nixa, MO
    Here's a shot of my OEM EVb installed:
  8. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    So, do you really think there is a benifit from playing with such a button all the time?...
    If you can only run a couple of miles on battery alone.... what would be the advantage?...just running through parking lots, or maybe deer hunting? :huh:
  9. windstrings
    6,280
    378
    Central Texas
    hey..nice steering wheel... is that a leather aftermarket option or a custom wheel?
  10. windstrings
    6,280
    378
    Central Texas
    Quote took from this site:
    http://privatenrg.com/#100kBrakePads
    The system doesn't provide lubrication to the planetary gear system during 'EV mode' or 'Stealth Mode' and that is partially why Toyota doesn't allow us very much EV time. Oil inside the hybrid drive housing (transaxle) splash lubricates the bearings, gears, and other moving parts while the ICE powered transaxle-oil pump (not the ICE oil pump) supplies lubricating oil to the planetary gear system.
  11. efusco
    19,891
    1,192
    Nixa, MO
    You can take that out of context and it sounds bad and scary doesn't it. Maybe you could be a auto journalist in Detroit! :blink:
    If you put it IN context you'll see he's talking about how far he can go with his nearly quadruple battery power he's installed in his Prius. He now forces himself to go out of EV mode after 7 miles. He also says that very little lubrication and splash is required.
    Earlier you asked if I thought it made a difference. The easy answer is "yes". But I use the button very judiciously. You know how there's sometimes a delay for the ICE to shut off as you're approaching a stop light and sometimes it doesn't shut off for several seconds even after you've stopped? Well I use the button to basicly tell the car "I'm fixin' to stop, so shut off." So maybe as much as 1/2 mile or more before a stop light I'll go into a glide, as my speed drops below 34mph I tap the EV button to force the ICE off (in case it wasn't already--sometimes it's hard to tell) and to prevent it from 'accidently' coming back on until I'm ready to leave the stop light.
    You know how sometimes you'll be at a stop light and you know the timing and you know that you won't make it through the green light b/c there are too many cars in front of you? I use it then so I can just scoot forward in electric mode and inhibit the unnecessary ICE spin up (which consumes a lot of energy) just to stop after 50 feet and shut off again.
    I use it as I approach home and tap the button some 1/4-1/2 mile before my garage as I can glide home with little or no additional power being used...just my momentum.
    I use it in the morning as I pull out of the garage before driving the 100 or so feet down my drive way to grab the news paper.
    I use it at drive-throughs so the ICE doesn't spin up as I pull around.
    I use it in school zones when going ~20mph since the ICE is inefficient there.
    There are lots of bad times for using the EV mode--if you have to go as far as 1/2 mile and then you're going to keep driving (ie. pulling from your home to a highway on-ramp) you're probably just as well to run the ICE without the EV button to keep the battery SOC high.
    In MOST cases using the battery alone to accelerate from a stop/drive is less efficient than using the ICE. Exceptions are very slow trips where the ICE starts and stops multiple times during a short distance b/c it takes quite a bit of battery power to spin up the ICE + you burn gas. Learning to recognize those situations takes time and experience and practice.
  12. efusco
    19,891
    1,192
    Nixa, MO
    Wheelskins cover. BTW, it doesn't look so 'royal blue' in real life (the flash brought out the color a lot), much more subtle color tone--which I'm glad of.
  13. windstrings
    6,280
    378
    Central Texas
    Seems like you have a very nice handle on the use of the EV button. I too am a bit technical and having a button to play with makes things all the funner to use.
    But I can see why toyota pulled it from the american market. I work on and build on computers alot for other folks and I'm always amazed how many folks love to learn techy stuff, and others fear it like the plague.
    Many folks would get confused with the use of the EV button. They need to offer it professionally installed if desired as an option. And then warn or teach of the uses.... I think Japanese are probrably more techy than americans in general.. but I"m only supposing.
    I too would like to have one, since they are so cheap to install.. but it looked a bit complicated to get it installed... maybe offering as an option would be nice?
  14. fleubis
    fleubis New Member
    That is the button to run on Battery until it reaches a certain discharge level at which poing the ICE kicks in.
  15. Seaside Harry
    Seaside Harry Junior Member
    78
    17
    Chesapeake, VA
    2014 Prius v wagon
    Dr. Fusco: Sorry to continue with this off-topic tangent, but I was also curious about your wheel cover. Do you actually have the Wheelskins "Cobalt," regular "Blue," or the "Sea Blue" color?
  16. efusco
    19,891
    1,192
    Nixa, MO
    I believe it's the cobalt blue. In 'normal light' it actually looks sorta blue/gray (more gray than blue) against the black. Only in the brightest direct light would someone see it as the blue in the photo.
  17. jacaufie
    jacaufie New Member
    104
    Hillsboro, Oregon
    Dr. Fusco,
    I took a peek at the 'Factory' EV button installation and it appears at first glance to be a nightmare when compared to the Coastal version. Did you do the mod yourself? Was it as painful as it appears?
    The Coastal mod sure looks simple, but I'd love to have the actual EV button to play with. :)
  18. Astrotoy7
    Astrotoy7 New Member
    108
    Melbourne, Australia
    lolz....thats pretty much the only time I have ever used it !!! I call it the "drive thru" button :p
  19. efusco
    19,891
    1,192
    Nixa, MO
    The factory button does require a little "doing". You need to use a soldering iron, you'll need to tap the dimmer (if you want the button to light up), and you'll need to fish a wire across from the ECU.
    Whether it's a "nightmare" or not depends upon how handy and adventurous you are. I do very little with electronics but have had a good time working with my Prius and extending my knowledge and experience and comfort level with this stuff.
    The factory EV button is fun to play with, I like having it to show off and look at...there isn't anything to point at/show other people with the coastal mod. That said, the Coastal EV mode is very easy to install (other than the stinking pin in the connector frustrations folks so often experience).
    I just suggest reading both articles...my original one on installing your own EV button and then the one specific for the OEM EV button itself. I've not yet heard of anyone doing any damage to their car or being unsuccessful with the factory EV button, but then this may be a self-selecting population of do-it-yourselfers.
    I didn't check your location before starting this reply, but if you're somewhere where there are other PCers living you may be able to find one who's done one of the EV installs who'd be happy to come over to help you do your install...sort of a 'hand to hold' for confidence.
  20. jacaufie
    jacaufie New Member
    104
    Hillsboro, Oregon
    Ah, I missed your excellent installation post. Very detailed; thanks!
    This sounds like something I could do. However, the Coastal mod might be more 'stealthy' and less likely to be noticed by the Toyota techs. Warranty issues and all that...
    I'm in the Portland Oregon area. I'm sure there are others who might be able to help. At this point all I need is the car. :)
    Thanks for the info.
