ev range 45.3
Discussion in 'Prime Fuel Economy & EV Range' started by poohbear1953, Jul 24, 2021.
  1. poohbear1953
    poohbear1953 Junior Member
    27
    26
    provo,ut
    after my last trip my 2017 prime ev range broke 45 miles range...came in at 45.3 . 101_2845.JPG
    Tideland Prius and Rmay635703 like this.
  2. schja01
    schja01 Senior Member
    1,866
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    Running on fumes?
    52,703
    you got the 'special edition' :p
  4. Rmay635703
    Rmay635703 Senior Member
    2,684
    1,722
    Somewhere in Wisconsin
    2013 Chevy Volt
    That is a definite accomplishment
    I’m happy with 65 miles on my Volt and the battery is twice the size
    Was this a “round” trip
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Just to be clear. The GOM showing 45.3 miles is not the same thing as actually driving 45.3miles all on EV mode without switching back and force between EV and HV modes. I can make the GOM show 50 miles (which is the top limit of the display) but would be almost impossible to drive 50 miles continuous EV mode on a round trip (that is without the help of gravitational pull on a long downhill).
  6. poohbear1953
    27
    26
    provo,ut
    yep, about 1/2 gallon left in the tank but with 45 ev range i'm not to worried ...will put a 1/2 tank in next week and that 1/2 tank will probably last till next year ....my last 1/2 tank i put in last August !!
  7. poohbear1953
    27
    26
    provo,ut
    yes i'm well aware of what your saying BUT it still will get a very good ev range out of that 45.3 !
  8. poohbear1953
    27
    26
    provo,ut
    yes , about 120 miles round , turned ev off on way to location and ran hybrid mode and then ran ev on the return ....it's a slight higher elevation trip , went from 4500 elevation to 6100 going , so on return it obviously reverses and it was a normal road with hills , twists and turns , etc. and even a few stop lights thrown in... ....when i left on the trip my ev read 44.7 , after returning and charging it read 45.3...
