EV Range.. Do a test post results
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by benalexe, Oct 21, 2012.
  1. benalexe
    benalexe Member
    198
    30
    Commack, New York
    So I was curious how many miles I was really getting in EV mode. So I did this. Fully charged car. Reset odometer. Drive in EV Mode only with NO AC. How many miles did you get on straight EV? What did the EV indicator say you were going to get prior to starting.
    Today I got the following
    Indicator told me I was going to get 10.1
    I got 9.6 miles
    No A/C or defroster
    Around town driving some hills but nothing major
    Temperature outside about 50 degrees
    Post your results. Curious to see how we all compare.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    When I went to the EV event in Ann Arbor, Michigan I took side streets that had a max. speed limit 0f 25mph. I went about 10 to 15 mph till ICE kicked in at EV depletion. EV indicator at beginning was 12.6. Trip odo at time of ICE kicking in was 15.4 miles. The area I live in is flat, no hills.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    normally when I drive to work, 2.7 miles, one way at 35 mph my EV is at 11.9
  4. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    I always reset my trip A meter each morning before i go. I have gone 17EV miles before, when my estimate was only 12.9
    and visa versa....when i am in a hurry and drive faster, i have only gone 11.5 miles, when my estimate showed 14.2
    The first thing you can do to help, is google your route, i go somewhere different many days...so i google it, and find SIDE ROADS that are 30mph where possible. This is the only way to get serious EV distance, to go slow.
    COMMON SENSE.
  5. bisco
    51,154
    late april, when i got it, i was getting 14-15. then as the weather warmed, i was up to 16-17 even with some a/c. now, with cooler weather again, (only 50's and 60's) i'm back down to 14-15. and when i come home at night with the lites on, i lose about another mile. all the same routes avg speed high twenties, 300' elevation change from one end to the other. i thought i was getting better mileage as the car broke in, but now i'm thinking it's weather related.
  6. benalexe
    benalexe Member
    198
    30
    Commack, New York
    Wow I am surprised I am getting only 9.6 I guess I am too hard on the pedal? I am concerned that going too slow is not safe either.
  7. bisco
    51,154
    what was your average speed at the end of your test? i drive the limit or just under if no one is behind me. 4.5 miles at 35-40, 2 miles at 50-55 and 1 mile at 20-25, somehow averages out to 27-28. i only have 3 stops which makes a big difference, no momentum loss.
  8. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    If your are Googling your route, try the bike route option. I found a sneaky back route which was a tiny bit longer, but all level. Well, as level as it gets here in Maine.
  9. Last week I tested my range. The EV PROPOSED 12.2 I actually got 15.3 A lot of construction was going on so the speed limit was 25 mph.
  10. Adam Leibovitch
    498
    102
    I have been managing about 14 in the city the last few days. I keep as much of the car turned off as possible except the speakers of course! Its not saving me that much money, I only do it on 70 degrees days, if its freezing or 90 degrees out I sacrifice the 3-4 miles for AC, Heat, etc.
  11. rockerdan
    427
    83
    Wheatfield NY
    Keeping speeds down and slow takeoffs help alot....i aim to keep HSI 20% or less always, tricky when people ride your nice person...I have pulled off shoulder many times with warning flashers on my backroads, as there is little to no traffic.....lol
    Dan
  12. benalexe
    benalexe Member
    198
    30
    Commack, New York
    What is hsi?
  13. rockerdan
    427
    83
    Wheatfield NY
    pic in my sig...screen title
  14. innerpri
    innerpri Junior Member
    55
    MD
    Hybrid System Indicator, like the one rocker dans pic. I had a strange drive to work today, started with an EV of 12.2. I usually get to my work 15.9 with .5 to spare on EV. I got behind a moving truck, super slow, so I guess I could not pulse and glide and regenerate as much as I usually do, I only got 10.6 actual miles out of my EV. Variables, Variables, Variables.
  15. bisco
    51,154
    that's odd because some have reported up to 25 miles in slow and go traffic.
  16. benalexe
    benalexe Member
    198
    30
    Commack, New York
    Duh. I should have know hsi. But what is pulse and glide
  17. Adam Leibovitch
    498
    102
    They have to be travelling downhill or have an extra battery. No one is magically getting twice as much. As long as the weather is nice you can pretty reliably get 14 miles if you keep all the extras off and drive gently.
    To be more accurate we should also be checking our energy monitor for amount of watts regenerated to get a better estimate. With those 14 miles I have alot of those little 50watt regeneration icons.
  18. bisco
    51,154
    well, i haven't done it, but i haven't driven 2 or 3 miles an hour long enough to know.:)
    pulse and glide is a hypermiling technique explained in many threads here and also can be found in an internet search.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you could walk:LOL:
  20. bisco
    51,154
    believe me, there have been times on the highway i wished i could have gotten out and walked!
