EV Range Estimate Capped at 50.0
Discussion in 'Prime Technical Discussion' started by PiPLosAngeles, May 14, 2019.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Anyone notice the EV range estimator is capped at 50.0 miles? I know it's a hard limit because it reaches 50.0 miles at 96% SOC and never goes above while SOC goes to 100%. Then, while driving on EV, it stays 50.0 miles until I get to 96% SOC. A little math tells me that my real estimated EV range at 100% charge is somewhere around 52 miles, but the car refuses to display it.
    dalcon95, mr88cet and utsug like this.
  2. schja01
    schja01 Senior Member
    1,842
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Mine is currently capped at 27. ;)
    Clark_Kent and bisco like this.
  3. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    Just switch your screen to the miles/kw . That ones max is 99.9 miles/kw
    which if you can sustain that mark you'll have driven almost 550 miles.
    52,351
    how do you get the estimator to 50 miles?(n)
    Data Daedalus likes this.
  5. Tideland Prius
    16,611
    What? Holy. Do you have the highest range in the US?
  6. bisco
    52,351
    must live at the top of a very long hill...
    Data Daedalus and HPrimeAdvanced like this.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,963
    New England
    Wow! 50 miles EV range!!! That would be ~8.3 miles/kWh. PRIME is rated to only ~4 miles/kWh. Are you sure you are driving PRIME, not Clarity??? AMAZING if true.
  8. bisco
    52,351
    it's in his first post pic
  9. Salamander_King
    11,024
    8,963
    New England
    Yeah, I see it. Seeing is believing. ... But well ... still unbelievable. :cautious:
    HPrimeAdvanced likes this.
  10. fuzzy1
    10,602
    Probably that same way I peg my Gen3 non-plugin at 99.9 MPG for nearly 100 miles.
  11. a_gray_prius
    2,927
    783
    IL
    I believe it. We hit like 45 estimated last year. The last picture I took (because it was getting completely unrealistic) was at 42.
  12. Salamander_King
    11,024
    8,963
    New England
    So, you are saying the number is just for the GOM and not the actual EV range you can achieve? My GOM has been pretty accurate in estimating my true EV range ~32 miles.
    pghyndman and HPrimeAdvanced like this.
  13. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    I did that yesterday
    Salamander_King likes this.
  14. Salamander_King
    11,024
    8,963
    New England
    Did you actuary drove >50miles EV mode?
  15. bisco
    52,351
    the gom is based on past driving. yours is accurate because your driving is probably fairly similar most of the time.
    but if you did something completely different (like starting at the top of a 100 mile hill or something) it would not be as accurate.
    a more realistic analogy for me is that i'm currently showing and getting 12-13 miles around town.
    but if took her out on the highway, i'd probably get around 6.
  16. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Are you actually getting near 50 miles per charge, or is it just being wildly optimistic?
  17. Salamander_King
    11,024
    8,963
    New England
    Yes, I perfectly understand that past performance is no guarantee of future results and your mileage may vary, but in order to get that 50 miles EV range displayed on GOM, you have to do something to get the car think you can go 50 miles on EV. Like your example of starting at the top of a 100 mile hill. So, if you are doing this every day, then yeah you can actually achieve 50 miles of down hill drive all on EV. But I got impression that some people who are getting overly optimistic estimate on GOM are actually not achieving the goal either in the past or in future. So, my question is this. Does GOM often estimate overly optimistic range that is realistically impossible to achieve, or is that estimation actually based on the actual past performance despite very rare and hard to replicate?
    #17 Salamander_King, May 15, 2019
  18. bisco
    52,351
    i have never seen the gom overly optimistic. what posts give you that impression?
  19. Salamander_King
    11,024
    8,963
    New England
    Neither have I. As I stated, my GOM has been fairly accurate in estimating actual EV range. That's why I asked the question to @a_gray_prius. His comment made me to think he is seeing overly optimistic range.
    #19 Salamander_King, May 15, 2019
    Tyfly and bisco like this.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    I’m not sure whom you’re replying to, but FWIW, my drive to work is 19 miles, but I need to charge to 21ish on the GoM to make it there reliably, with pretty much zero when I get there.
