EV Regenerative Braking using the "B" drive in EV Mode
Discussion in 'Prime Main Forum (2017-2022)' started by ed4271, Aug 3, 2018.
  1. ed4271
    ed4271 Member
    107
    64
    US
    I do not know if this has come up in a post so excuse me if it has. When I am driving in EV mode around the suburbs I drive in the "B" mode. I noticed I get great regenerative braking while using the "B" mode while driving. I do not use it while I am driving on the highway or when the ICE is running. The manual states:
    ■About engine braking
    When shift position B is selected, releasing the accelerator pedal will apply
    engine braking.
    ●When the vehicle is driven at high speeds, compared to ordinary gasoline-
    fueled vehicles, the engine braking deceleration is felt less than that of other
    vehicles.
    ●The vehicle can be accelerated even when shift position B is selected.
    If the vehicle is driven continuously in the B position, fuel efficiency will
    become low. Usually, select the D position.
    I feel if you are driving in EV mode while "B" is engaged are getting same efficiency in driving. The ICE is not on so you not engin braking. I believe this will save on your brakes. It is like one pedal driving like in the EV cars.
    Your thoughs.
    49,397
    so the whole point is same efficiency, and less pad wear?
    ed4271 likes this.
  3. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    I didn’t use it much. The fact the brake lights are not illuminated is enough reason to be cautious.
    J
    BrettEG likes this.
  4. 2015BlizzardPriusFour
    2015BlizzardPriusFour Active Member
    171
    142
    Central Valley CA
    I’ve been toying around with that a bit too. Even in “B” the regenerative braking is not as heavy as it is in my electric smart. The argument of brake lights, well, my smart does not trip the brake lights on deceleration and I have yet to get hit.
    iPad ?
    ed4271 likes this.
  5. Washingtonian
    Washingtonian Senior Member
    715
    616
    I have only used it once, when coming down a long mountain road at Olympic National Park. It seemed to do what it was supposed to do but I don't know if it would have charged the battery any more than if I had just left it in D.
  6. ed4271
    ed4271 Member
    107
    64
    US
    It's the same when you are approaching a light you take your foot off the gas and coast to the light and then press the brake pedal to stop at the light.
  7. schja01
    1,744
    1,162
    Chicagoland
    2018 Prius
    Not really. B mode decelerates much faster than coasting.
    Dudley1030, benagi and ed4271 like this.
  8. 2015BlizzardPriusFour
    171
    142
    Central Valley CA
    But it’s still similar to downshifting a manual transmission. When downshifting the brake lights don’t engage either, but it’s still very common to do.
    iPad ?
  9. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    Will engine be turned on and burn gas in B mode?
  10. schja01
    1,744
    1,162
    Chicagoland
    2018 Prius
  11. schja01
    1,744
    1,162
    Chicagoland
    2018 Prius
    I guess I value my rear bumper more than you do.
  12. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    B mode shuts off the gas and make the ice an air brake, ie, the ice turns and its friction slows down the car.
    The gen2 manual warned against excessive use of b mode because it would wear parts.
    Cruise control won’t engage while in b mode.
    When running electric, why turn the ice?
    Dael likes this.
  13. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    I've seen recommendations to avoid using B when driving; just use it when decelerating. I don't recall the reasons. It is said to give lower efficiency than driving in D.
  14. ziggy29
    ziggy29 Member
    127
    64
    North Oregon Coast
    2018 Prius Prime
    Deceleration and down steep hills when you would otherwise have to repeatedly brake in order to maintain speed. That said, it could certainly be used to decelerate before red lights and stop signs and such, though I wouldn't do it in heavy traffic with vehicles following behind me fairly closely. I want the drivers behind me to see my brake lights when I'm slowing down.
    From the 2018 Prime Owner's Manual, page 333:
  15. Washingtonian
    715
    616
    Are you sure that cruise control won't engage in b mode? The only time I used b mode was on a long down hill mountain road (4 or 5 miles) and I used cruise control at the same time. Worked OK until the person ahead of me turned right and the CC slammed on the brakes.
  16. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    I use it all the time when I’m in ev mode. I wish the car had one pedal driving but this is at least 20% of the way there.
  17. ed4271
    ed4271 Member
    107
    64
    US
    Yes cruise control will not engage while you were driving in the "B" mode. And if you are in cruise control and switch it to the "B" mode the cruise control with disengage.
  18. Trollbait
    11,513
    But no more faster than than downshifting in an ICE car, and people have been doing that in addition to the braking to stop for generations. I did it regularly in a the HHR without incident.
    Both of the above quotes apply to the hybrid, and maybe the PiP. The size of the Prime's battery means that it only uses regenerative braking while in B for most cases.
  19. schja01
    1,744
    1,162
    Chicagoland
    2018 Prius
    If you’re looking for me to validate your unsafe habit look elsewhere.
    #19 schja01, Aug 6, 2018
  20. Trollbait
    11,513
    o_O
    Use of engine braking to control speed and slow down is a common practice. Plenty of time has passed for evidence of such being unsafe to accumulate to the point that the vehicle code would require the brake lights to light up with it, or even remove lower gear choices from the shifter.
    Not every car decelerates at the same speed while coasting. One car in drive can decelerate as fast as one in a lower gear or B. I need to make use of downshifting in the Camry because it will coast far longer than most other cars I have owned. It is up to the following driver to be paying attention to the traffic ahead. For all they know, the car ahead may not have working brake lights.
