EV replenish from HV
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by john1701a, Mar 17, 2012.
  1. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    The first time I saw EV range climb while driving, it was 37°F outside and heat/defrost was needed. Since the engine was now running, why not use some of that energy to generate electricity?
    That made sense. It's taking advantage of the power-split ability, allowing the engine to run in an optimal fashion. Power flow is divided & directed in the efficient portions to the needed components.
    Today as the EV range approached only 1 mile remaining, I switched over the HV mode. Naturally, the stoplight I was racing to changed sooner than expected. I was stuck there, but witnessing the warmup cycle for the very first time with an aftermarket gauge. That was intriguing.
    Warmup for PHV is different from the regular model. It wants to keep the engine off as long as possible. So, rather than shutting off as soon as the coolant temperature hits 103°F, it continues. PHV attempts to build up a heat reserve to allow it to shut off the engine as quickly as possible when still in HV mode.
    The result of that engine running, while I was still stationary for that horribly long stoplight, was EV replenish. The range went up. It started at 1.3 and increased to 1.7 miles. I then had to climb up a large hill and glide down the other side. By the time I got to my turn, engine & regen contribution had bumped EV range up to 2.2 miles.
    That was sweet!
    9 people like this.
    52,100
    excellent!
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    That's a pleasant surprise.
    The battery is no longer used just to capture regen brake energy. It is now being used to extend the EV range. It makes sense to do so if the gas engine is running to provide cabin heat or warming up the catalytic converter. Nothing goes wasted.
  4. usdmattiphone
    usdmattiphone Member
    147
    58
    It's amazing how much strategic braking can regen the EV. I was able to get .3 miles of EV just going down a brief hill.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    I would like to know, by how much did your MPG gauge change during this warmup time? Would the distress of watching that number plummet outweigh the thrill of seeing EV miles increase? This just screams "coolant temperature hack." The last thing you want is for the engine to be idling and charging the battery. How is this any different from from running a portable gas generator at home to charge the pack? For maximum fuel economy, if the car isn't moving, the engine should be off.
    Except Gas
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Remember, Prius PHV is rated eAT-PZEV. How do you propose saving more gas while maintaining that (includes emission and hardware warrenty)? Hacks may decrease some gas usage but the emission may increase. The Cat may be short lived with the non-complete warmup cycles.
    It seems the strategy used here is to complete the Cat warm up because Prius' top priority is low emission. The second is the efficiency. The excessive power is stored in the PHV pack.
  7. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    My point is this: Most people who get a PHV want the highest possible MPG. If the engine is idling at a stoplight, you will never get there. The car is charging the battery, because in the minds of the designers, "We're pretty much screwed by AT-PZEV (or the priss-driver wanting heat), so we're going to charge the battery in this case to minimize the waste." I have the coolant temp hack in my Gen II courtesy of ccdise for the last 10,000 miles, and get tanks in the 55-60 MPG range. It is very well worth it. Come on guys, the PHV is a hypermiling test-bed. If you've got one, put your skills to work and get the most out of it.
    Let the plug charge the battery. Turn on the ICE when the car is moving and likely to remain that way for a few minutes. Arrive at your destination with zero EV miles remaining (or have a bit left if in EV mode all the way), and plug it in.
  8. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I believe john1701a was doing just that, and got caught by a stoplight.
    He then noted how even a warm-up cycle is used efficiently by the Pip!
  9. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    fwiw, i noticed on drive home from VA yesterday that using B to assist slowing down would regen about 0.2 to 0.3 EV miles on about a 1 block usage. Eastern NC doesn't have a lot of hills.
    2 people like this.
  10. 9G-man
    1,273
    194
    Atlanta, GA
    Neat Pic
  11. HillCountryEVer
    HillCountryEVer New Member
    75
    Kerrville, Texas
    I have a 2011 G3 and am planning on adding a PiP, does anyone know if it causes any problem to drive mostly on B? I looked briefly at the manual and didn't see anything. I've also read that BMW (in their i series) and others use the stronger regen in normal driving to achieve a more effiecient experience which I think would be equivalent to driving in B mode.
    Any thoughts? :confused:
  12. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I have to assume that B will tend to turn the ICE of the PHV just like in the liftbacks and c's and v's, thereby wasting regen opportunity any time the pack is not full at the end of the regen opportunity.
  13. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    You would have regened more by not shifting to B. B is converting some of the kinetic energy into heat (waste) in the ICE (like engine brake).
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Wow this is a new ball game - to regain the most EV range during a trip.
  15. crewdog
    493
    388
    Woodstock, GA
    Perhaps so; This week I'll try and conduct a completely unscientific test on a freeway exit that exits downhill from a 60 mph lane about 0.2 miles to a stop sign. In the Gen II, I would occasionally use B to assist slowing down if no one was behind me, and no cars were in front lined up at the light, just to save a little brake wear.
    It will be interesting to see which way garners more regen in that short a distance.
  16. 9G-man
    1,273
    194
    Atlanta, GA
    Oh boy, time to revisit this link.,,,,Please take a look.
    http://techno-fandom.org/~hobbit/cars/b-mode.html
    6 people like this.
  17. HillCountryEVer
    75
    Kerrville, Texas
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You should use B Mode any time you would use L in a 'normal' car, almost never. It is to protect the friction brakes on long down hills. Spinning the ICE as brakes is 100% loss of energy, recharging the HV Battery is only about a 70% loss. Not hitting the brakes at all is a 0% loss. (In the Gen 2, the ICE will spin above 22 MPH, the cutoff will vary on the other Prius models)
  19. hill
    8,836
    Aint that cool though? :rockon:
    I've witnessed regen in the Leaf. The highest mountain in the L.A. area is mount baldy. We were just below the 5,000 foot level. By the time we'd reached the base, the charge had gone from about a 7kWh reserve to a 15kWh reserve. The leaf can regen at up to 30kW. What's the max for the PiP if anyone knows ?
  20. john1701a
    12,818
    5,303
    58
    I went through 2 warm-up cycles yesterday.
    When EV is available, it appears as though the engine-off threshold is 130°F.
    When you're back in HV due to the pack being depleted, I confirmed the system acts like a regular Prius. That means ECO has a engine-off threshold of 103°F.
