EV SWITCH Install pdf's
Discussion in 'The File Library' started by southerncal, May 31, 2005.
  1. southerncal
    southerncal New Member
    PDF FILES ON EF SWITCHES
  2. lspfrida
    lspfrida New Member
  3. lspfrida
    lspfrida New Member
  4. lspfrida
    lspfrida New Member
  5. benighted
    benighted New Member
    530
    Westport, WA
  6. davidstdy
    davidstdy Guest
    Here is a link to one type of install out there and a PDF of yet another.....There are more out there if you do a search.....
    A EV PDF
    C Wagner and SteveWlf like this.
  7. MBranstein
    MBranstein New Member
    288
    Prospect, KY
    Does anyone have any directions for implementing Coastal Dave's Cruise-Control EV switch?
  8. Kate Harvest
    Kate Harvest Member
    105
    Vancouver, WA
    Just put a switch in on my 2007 following these instructions and it works but it doesn't beep to acknowledge it's been turned on like the PDF says it's supposed to. Anyone have any clue why that might be?
  9. bisco
    52,401
    this is my second favorite thread.:love:
  10. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The UK Prius that has the EV button as standard fitment does not beep when going into EV mode only giving 3 beeps when exiting the mode through going over the EV speed limit (31 mph registered 29 mph actual). It does not beep if you exit EV mode by pushing the button to cancel EV mode .
    Cruise control cannot be used in EV mode.
    John
    #10 Britprius, Sep 24, 2015
    C Wagner and Kate Harvest like this.
  11. Chris Rafoi
    Chris Rafoi New Member
    Fiji
    Can someone please tell me what is the EV switch for?
  12. bisco
    52,401
    welcome! it's for showing someone how the car can move around without the engine, of it the engine is warm enough, you can move the car out of the garage, etc. without the engine starting. it's pitiful really.
    C Wagner likes this.
  13. Britprius
    5,194
    1,922
    It is for forcing the car to run in electric mode only (Electric Vehicle). It will only do this if the HV battery has a reasonable state of charge. The engine temperature has no bearing on it's use as long as it is used before the engine has started "about the first 7 seconds of going into ready mode". If used incorrectly it can cause the you to use more fuel. In certain circumstances it can save fuel.
    Moving the car a short distance when cold in EV mode will save the engine starting and running it's cold cycle requiring more fuel than when it is hot.
    I live near the top of a hill, and by going into EV mode part way up the hill "at the same point each time" when returning home I can finish that part of the journey using no fuel. On starting my next journey I can go into EV mode to reverse out of my driveway and roll down the hill to the bottom recharging the battery fully using regen again saving fuel.
    John
  14. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    i modded my US Prius base 2007 a few weeks ago. just wanted to confirm everything above. also.
    If it doesn't work when pressed, it will flash a message saying "Cannot change to EV mode", and beep thrice.
    If it does work, it will switch the MFD to Energy mode if it's in another mode
    I grounded by loosening a screw near the HV ECU, wrapping the ground wire from the switch around it, and tightening.... seemed easier than splicing into the OEM wire harness. I noticed a lot of sharp metal so I used a lot of tie wraps to keep the wire from moving around.
    Was it worth it? Yes! I can pretend I have a really slow Tesla for about 3 minutes. That is super fun.
    But also there are legit times when some people would rather not have the engine on, so it could make sense for a small number of niche cases. For example if you are in the middle of a bison herd, maybe you want to listen to the bison and make sure the engine stays off for a little while.
  15. C Wagner
    C Wagner Member
    183
    60
    Boston
    Hi Everyone - this is a very old thread, but an interesting one. I just bought a used UK EV button and am wondering if Evan Fusco's PDF instructions from above (thanks!) can be improved for actual OEM EV button installations. Is it possible to get the EV light on the momentary switch to light? I didn't particularly like the part of the instructions where he says 'remove between 1 and 3 wires...'
    Thx
    Todd Allan McIntyre likes this.
