Featured EV vs Guardrail crash test
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Feb 1, 2024.
  1. bwilson4web
    15,507
    Good thing only EVs weight "nearly 4-ton".
    Source: Crash tests indicate nation's guardrail system can't handle heavy electric vehicles | AP News
    Last fall, engineers at Nebraska’s Midwest Roadside Safety Facility watched as an electric-powered pickup truck hurtled toward a guardrail installed on the facility’s testing ground on the edge of the local municipal airport. The nearly 4-ton (3.6 metric ton) 2022 Rivian R1T tore through the metal guardrail and hardly slowed until hitting a concrete barrier yards away on the other side.
    “We knew it was going to be an extremely demanding test of the roadside safety system,” said Cody Stolle with the facility. “The system was not made to handle vehicles greater than 5,000 pounds.”
    My 2019 Tesla Model 3 weights 3,800 lbs, less than 2 tons with me, two dogs, and tool box on a truck stop, CAT scale. Remember, 5,000 pounds is 2.5 tons (1 ton = 2,000 lbs) for example:
    • 6,001-6,965 lbs :: Diesel RAM pickup
    • 5,635-6,217 lbs :: Cadillac Escalade
      • 5,557-5,810 lbs :: Cadillac LYRIQ (EV)
    • 7,625 lbs :: Lincoln Navigator
    • 6,329-8,435 lbs :: GMC Sierra 3500HD
      • 9,063 lbs :: GMC HUMMER EV Pickup
    #1 bwilson4web, Feb 1, 2024
  2. ETC(SS)
    6,537
    Guard rails are only 'guards' - something meant to slow down or deter......otherwise they would call them something else.
    49,358
    Guard rails are like the coast guard, mostly there for idiots who get themselves in trouble
  4. bwilson4web
    15,507
  5. Trollbait
    11,494
    They also did the test with a Model 3 earlier. It lifted the rail face up, and passed underneath it.
    Nebraska experts weigh highway safety and electric vehicles | College of Engineering | University of Nebraska–Lincoln
    I think the rail height had been increased to account for more trucks and SUVs on the road.
    Looks legit. A state posting of a federal agency document.
    https://highways.dot.gov/safety/rwd/reduce-crash-severity/guardrail-resources
  6. bwilson4web
    15,507
    I like their improved design: The SAFER Barrier | University of Nebraska–Lincoln
    On a 3-day trip to visit casinos in Tunica and Vicksburg, I saw a lot of ugly barriers left overs from earlier crashes. Between Jackson and Meridian, I passed an ugly accident that backed up traffic 4-5 miles. Totally blocked East bound, I-20 traffic.
    vvillovv likes this.
  7. Trollbait
    11,494
    Seems it needs a concrete barrier already in place to work. Guard rails are generally used in place of the barriers.
  8. douglasjre
    douglasjre Senior Member
    1,852
    646
    Orlando, FL
    Your Tesla weighs the same as my Prius. And the load rating of 195 tires exceeds what's needed (1650lb/ea). Why is Tesla saying we need special high load tires
  9. Isaac Zachary
    Isaac Zachary Senior Member
    1,824
    867
    A guardrail saved my life once. Or at least it kept me from flying over a precipice. P.S. I was not the one driving.
    I feel that driving a small, lightweight car has some charm to it. The Avalon feels like a boat. My favorite car to drive was my 1972 VW Super Beetle, and it only weighed 1,874 lbs. when stock. Of course buying a car isn't about buying something I like anymore, It's about practicality and safety.
  10. bwilson4web
    15,507
    Speculation, it may be to handle the very high torque and power from the drive wheels. For example, the effective load on the tires is multiplied by the acceleration "G" force.
  11. Trollbait
    11,494
    The instant torque applied to unmoving tread on the road surface might be more of the cause than being high. The relatively gradual increase with ICE cars is applying less shear forces.
    bwilson4web likes this.
  12. austingreen
    austingreen Senior Member
    13,563
    4,101
    Austin, TX, USA
    Better tires are needed if you are accelerating or braking faster, or taking turns at higher speeds. I believe the rwd and awd tesla model 3 use the same tires, so they are likely speced for the under 5 second acceleration of the dual motor. This applies 4x more power to the tires than the prius. Driver can determine and there is a chill mode to keep acceleration lower.
  13. Zythryn
    Zythryn Senior Member
    6,232
    4,227
    I love smaller cars, as my recent Mini Cooper will attest.
    I feel our roads would be safer if the average vehicle size came down, not just due to the size/weight, but due to the psychology.
    Some people in big vehicles drive/behave more aggressively. (This is speculation on my part)
    I feel that aggression would be less in smaller vehicles.
    mikefocke, 3PriusMike and bisco like this.
  14. Isaac Zachary
    1,824
    867
    (y)(y)(y)
    I totally agree!
  15. Trollbait
    11,494
    You feel speed less the higher from the ground you sit.
    3PriusMike, Zythryn and Isaac Zachary like this.
  16. Isaac Zachary
    1,824
    867
    Another thing I dislike about heavier vehicles is greater rolling resistance.
    It's getting to the point that rolling resistance is starting to become a greater cause of inefficiency than aerodynamic drag, and aerodynamic drag hasn't improved all that much in the past 10 years.
  17. bisco
    49,358
    The law of diminishing returns
  18. Isaac Zachary
    1,824
    867
  19. bisco
    49,358
    Agreed, I was thinking about aerodynamics.
    Unfortunately, the free market continually drives larger and heavier vehicles.
    And as Bob w said, “Americans will do the right thing after exhausting all other possibilities “ :p
    Isaac Zachary likes this.
  20. douglasjre
    1,852
    646
    Orlando, FL
