Evaluating wear material in NHW11 trans pan at 125k
Discussion in 'Gen 2 Prius Technical Discussion' started by ChapmanF, Apr 27, 2008.
  1. ChapmanF
    15,561
    I changed the fluid in my 125k NHW11 tranny, and it was pinkish red
    with a smell not much different from new T-IV, but of course less
    transparent.
    There were two kinds of wear material in the pan.
    1. A very fine, silty, ferromagnetic mud, in pretty much a uniform
    thin layer over all surfaces, and domed up on top of the magnet
    to a depth about equal to the height of the magnet itself.
    2. Some macroscopically sized, non-magnetic, particles or chips.
    (The repair manual says these are likely to be bronze and represent
    bushing wear.) These were not uniformly distributed in the pan,
    but concentrated in two small heaps, each about the size of a dime,
    probably in locations having to do with the way fluid flows in the
    pan. One heap was just forward of the hump the drain plug mounts
    in, the other just abaft the magnet. Individual particles ranged
    from fine sand-grain to, umm, hangnail size. There were probably
    enough to fill a 1/8 teaspoon (0.6 ml) measure.
    I'll post pics later.
    Separating the magnetic from the non-magnetic wear material looks so
    easy in the repair manual, but in practice everything will stick to the
    magnet just on account of being covered in the magnetic mud. So the non-
    magnetic chips had to be picked out and /washed/ before I could be sure
    they weren't magnetic. Tedious. Very tedious.
    Though I bought an O ring for the pickup tube, I didn't end up removing
    it. There was fluid in the tube that didn't drain out because of surface
    tension in the pickup screen, and when I held a shop towel to the screen
    that broke the tension and fluid flowed out freely, and seemed to flush
    the screen. When the flow stopped the screen appeared clean and I could
    see perfectly through it and out the other side, so I left it at that.
    I was tired of standing on my head by that point.
    I refilled with T-IV and not WS, as it still seems to be the official
    Toyota spec. (I don't imagine this will be my last fluid change, so
    there will be chances to change my mind if need be.)
    So, for anybody with more experience than I have (which doesn't take much)
    at evaluating wear materials, what should I conclude about the condition
    of this tranny at 125k?
    -Chap
  2. Patrick Wong
    18,200
    6,472
    Hi Chap,
    Since you said that the old fluid was pinkish red and not near-black, my guess is that the factory-fill fluid had been changed by the prior owner. However it sounds like the pan had not been removed since the layer of the ferrous muck sounds much deeper than I recall when I removed the pan on my 2001 at ~60K miles.
    Is it possible that the non-magnetic debris is plastic insulation from the wiring? If in fact that debris is from the bearings, and you don't hear unusual noise when the car is underway, then no worries. I would say that your transaxle wear sounds normal pending identification of the non-magnetic debris.
  3. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    If that had been the original fluid, it would have been black, to say the least. I also second it has been changed at least once before, but the pan had not been removed
    I'm wondering how much muck will accumulate in the +2004 Prius, as there is no easy way to take apart the cvt. Just a drain plug and a fill plug, no pan.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    I changed my 07 at 6K miles. I wanted to get some better quality fluid in there. The magnet had about 1/16 of an inch film on it and the fluid smelled real good. I'm in the process of getting a PDA on it to add to Bob's fluid analysis study. I replaced it with the product linked below and the car runs perfect. I can't hear the drivetrain anymore at 90+mph.
    Red Line Oil: Gear Lubricants
    http://www.redlineoil.com/pdf/3.pdf
  5. Patrick Wong
    18,200
    6,472
    Hi Ed,
    That was a brave thing to do - being among the first to use a fluid other than Toyota ATF WS...
    What drivetrain noise did you previously hear at 90 mph?
  6. bwilson4web
    15,518
    You are using "Synthetic D6 AFT", the Type WS substitute, right?
    Did you pull a sample of the virgin oil for a baseline analysis? This gives you an idea of the relative amounts of additives already in the oil so combined with the analysis from the previous fill, you tell what percentage was replaced. We've found that in the NHW11 Prius, about 15-20% of the last oil does not drain even if the pan is removed. I like to use the ratio of viscosity, a bulk oil property.
    By all means, when you get a month or 5,000 miles, draw a small sample from the filler plug for an analysis. You want to make sure there are no chemical changes going on that might 'raise a flag.' You are probably going to be OK but I aborted my AMSOIL ATF test when the Cu levels starting climbing faster than I thought reasonable. I used the 5,000 mile sample to determine how things were working and calculate the residual oil.
    BTW, thanks!!! It is good to meet a fellow experimenter.
  7. ChapmanF
    15,561
    Interesting links to the Red Line products - and impressive to see that Bob's earlier observation about WS having a lower initial viscosity than T-IV, but diminishing less over time, turns out to be exactly what Red Line describes as the deliberately designed property of their D6. Go Bob!
    Patrick, I've never had one of these transaxles apart, so I wouldn't recognize what plastic might be used as winding insulation - wouldn't it be the thin, clear red varnish I'm used to on magnet coils typically? These chips don't look like that.
    They're opaque, reddish, and thick as a postcard perhaps. Unless there are some solid insulating parts in there made from an opaque hard plastic.
    I didn't pay enough attention in chem to think of a good way to distinguish a small chip of reddish bronze from a small chip of reddish plastic. I suppose I could prod one with a soldering iron and see if it softens.
    Cheers,
    -Chap
  8. Patrick Wong
    18,200
    6,472
    Hi Chap,
    I'm not sure what your unidentified debris is.
    For fun, I've provided a link to 34 photos taken of a disassembled Classic transaxle. Florian Steiper, the photographer, is an active member of Yahoo Prius Technical Stuff group, took apart the failed transaxle from his 2001, and shared these photos with group members early last year.
    Prius Transaxle - a set on Flickr
    Note that the drain pan magnet looks like it had a bad hair day. Hope that your magnet did not look like that. If it just looks like a swollen garden slug, that is OK.
  9. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    There are plenty of pix of the MG windings kicking around the
    net, including in the Argonne/Oakridge papers. Standard magnet
    wire enamel, from what anyone can tell...
    _H*
  10. bwilson4web
    15,518
    I have seen similar debris in my pan and photos from the Jesse change that Hobbit documented. I am speculating that these are fragments of the case sealant that have broken off and migrated to the bottom of the transaxle. I think as it ages it becomes more brittle and begins to lose the pinkish-red color. However, I've not had much luck getting a good assay of the material.
  11. ChapmanF
    15,561
    Oh, interesting thought. I guess if it could be just old cooked orange FIPG then I shouldn't be spooked at all.
    After looking at Florian's pics, I am wondering what's known about the common failure modes/sequence of events for these things. The visually obvious damage in Florian's case was a burnt winding, and that was the case also in the other gallery of transaxle postmortem pics that I've seen. So the fact that his magnet also had bad hair ... hmm ... curious coincidence, or some kind of causal relationship? Did some incipient mechanical failure produce some metallic bad-hair chips, that wound up getting involved in MG2 and scraping enamel off the winding? Or did a shorted winding create some outlandish magnetic force that caused the rotor to scrape, making chips?
    -Chap
  12. bwilson4web
    15,518
    If you can figure out a good way to resolve this, I sure would be appreciative.
    Once the problem starts, the initial short, nothing stops it. The wire loop couples with any rotor motion to pull power into the loop. It continues to heat the adjacent wires and the problem gets worse. There is a characteristics 'rumble' at the rotor rpm but by this time, it is too late. Error codes will report MG2 too hot but that is a direct effect of a magnetic coupled short.
    Florian has speculated a latent manufacturing defect. We've seen a number of failures including one that involved the replacement transaxle from a salvage also failing. My interest in transaxle oil is in part wondering if our transaxles have more in common with power transformers than we ordinarily think. Power transformer oil has unique requirements that include working in high temperatures and high voltage fields. Yet the differential gears run semi-submerged in the oil, which should promote foaming and micro-dieseling. Some of the older oil samples suggest this is going on, converting the 'transformer oil' into something else.
    This remains an interesting puzzle, even more so now that the NHW20 runs at twice the voltage of the original NHW11.
  13. Patrick Wong
    18,200
    6,472
    Hi Chap,
    If you have an ohmmeter, how about cleaning one of your larger pieces of non-ferrous debris, dry it, then see what the resistance is. If high, then it might be sealant. If low, then it is probably metallic.
    Florian said that the bearings did not appear to be worn, so your theory that the rotor was scraping is plausible.
  14. edthefox5
    10,096
    4,805
    Clearwater, Florida
    I was meaning that the entire drive train seems quieter to me since the change to synthetic D6.
  15. ChapmanF
    15,561
    Hmm, for some suitable value of 'plausible'. I would like to think that the rotor is supported on stout enough bearings that even worst-case magnetic fields from a short wouldn't pull it into metal-to-metal contact. I'm surprised, though, that Florian didn't seem to find, somewhere, some sign of metal-to-metal wear that could account for the bad hair chips on the magnet. Puzzling.
    -Chap
  16. rhc3v6
    rhc3v6 Red Hat Certified Engineer V6
    Middletown, NJ 07748
    2003 Prius
    I
    Could someone point me to the procedure for changing the transaxle fluid on a 2003 NHW11 and what fluid the dealer and others might recommend (Toyota type or Synthetic D6?).
    When I asked the dealer ~75K miles about trans fluid change they said you don't/can't do that but I am now discovering they were wrong. The car now has 120K miles and I want to change the fluid and if it is tested and safe would like to use the best fluid available or at least the same fluid that Toyota used.
    Thx!
  17. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Yes you are way way overdue.
    Its really easy. Uses Type T-IV fluid. Basically Dexron D4. Redline Oil makes an excellent D4 fluid.
    Or just dealer for fluid & while getting fluid get a new pan gasket too at the dealer. Gen 1 is 4.9 quarts.
    Just jack the car up in front. On jackstands.
    Remove the cvt side fill bolt first (to make sure you can get it out) and then drop the pan.
    Clean pan & magnet real good. Inspect closely with flashlight for any issues.
    Get a funnel with long extension and snake it through from the top of the engine. Install that funnel into the fill hole. Gen I is 4.9 quarts.
    Also Gen I uses mechanical shift cable linkage so spray some lubricant on that assy & cable to.
    There's hundreds of detailed posts about it just search and read them all and you can get a very good feel for it. Its easy.
    And your way way overdue for Inverter Coolant change too. Since your under the car I would do that to. That's really important and really affects mileage too. Again lost of posts to read to get complete understanding of that buts that's really easy too.
    Good Luck!
  18. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  19. Patrick Wong
    18,200
    6,472
    No. Five US quarts of ATF T-IV is the correct fluid for NHW11.
