Evaporator cleaning/deodorizing DIY.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A617, Mar 18, 2015.
  1. A617
    A617 Member
    213
    95
    OKC, OK
    So its springtime and that means A/C season, but unfortunately my a/c has been smelling like a dirty crusty gym socks, solution? Toyota's Evaporator Cleaning kit. Part number 00289ACRKT
    It comes in 2 cans 1 foam that you instill into the evaporator via the water drain and the other its a aerosol spray that deodorizes the vent, I bought this on Ebay for $20 while my local dealer wanted $49.99+tax for just the foam (my local dealer sucks btw) The can has some (universal) instructions written. this is my first time using this so if i made some errors correct me.
    What you'll need
    1 Toyota Evaporator cleaning Kit, part number 00289ACRKT
    1 Cabin filter
    *Before you begin set the temperature to low and turn off the car. Do not run the fan or start the vehicle while the foam is in the system!
    1. (Optional) Find your a/c evaporator drain line, this if you want to put a drain pan to catch it (to see what junks comes out) its located on the right side (passenger side) behind the engine you'll need some light to see the pipe sticking out.
    2. Due to access problem of the outside drain line i used this route, Go to the passenger side and remove the glove box and lower kick panel (similar to when you're replacing your cabin filter), then peel back the floor mat to expose the drain line from the evaporator,
    3.Disconnect the outside drain line from the evaporator
    4. The kit should have a clear line with a cone attached at the end, Insert the cone end of the line into the evaporator drain line first, then assemble/attach the line on to the foam spray (step 1) this will cause some to the foam to immediately discharge when you assemble it, remove the plastic protective cap spray trigger and press and hold the spray nozzle until 1/2 of the can has been discharged into the evaporator.
    5. After discharging 1/2 of the can pinch the evaporator drain line, disconnect the cone from evaporator and reattach to the evaporator line to drain outlet and let the foam do its job, the foam will turn into liquid and it will come out on its own it will take around 10 mins to completely drain all of the product, repeat steps 3-5 for the other 1/2 can.
    Comment. When you spray the foam goes in the evaporator compartment expands covering every little possible nook and cranny of the evaporator thus coating it and cleaning/deodorize/disinfecting it after 5 mins the foam turns into fluid and it runs out of your evaporator drain line . Heres what came out, the color is originally brownish, there were some fine sediment at the bottom of the pan.
    6. After completing the other 1/2 can of foam and theres no more liquid coming out of the evaporator drain pipe, reinstall the carpet, but leave the glove box and lower kick panel open.
    7.Get the aerosol can (step 2) go to a well ventilated area, remove the cabin filter, close all doors and windows,
    Set the climate control to the following: a/c off, temperature low and fan high (max) and outside air (see picture for clarification),
    Locate to the outside fresh air vent (located on passenger side) and start spraying in left to right sweeping pattern, use the entire can, and let it run for 5 mins.
    After 5 mins has elapse open the window and let the excess aerosol/scent vent out.
    Thats about it dont forget to replace with a new cabin filter and reinstall the glove box. your car vent will smell clean, the scent is VERY strong for the first few hours and it smells plesent almost like lemon, synthetic lemon to be exact.
    I don't know how long it will last but i'll update this page time to time.
    #1 A617, Mar 18, 2015
    Fostel, James Powers, R-P and 10 others like this.
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Nice thread.
  3. qdllc
    qdllc Senior Member
    1,370
    399
    What does "synthetic lemon" smell like? :cautious:
  4. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    Nice write up! I plan to do this as part of my car's "Spring Cleaning."
  5. mrbigh
    3,686
    699
    Long Island, NY
    It will be hands to work very soon....(y)
  6. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Thanks for the write up, the pics really help. That will save a lot of time, I like the idea of working at the connection for the drain tube.
  7. A617
    A617 Member
    213
    95
    OKC, OK
    ***UPDATE***
    Its almost been a week since i've done this and i've been using my a/c quite often almost everyime i drive, and so far so good, the scent from the product (synthetic lemon) has dramatically decreased down to very faint, vents is beginning to smell neutral, no foul odor as of yet. Next update 1 month from now.
    visualfx likes this.
  8. visualfx
    visualfx Junior Member
    New York
    Great write up. Will be adding this to my to do list
  9. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Just did this, here's a video :D
    frodoz737 likes this.
  10. gliderman
    gliderman Active Member
    751
    223
    Nice video. I could not find the toyota kit. Searched ebay and amazon and google. Any hints?
  11. milkman44
    591
    386
    Ky
    google.com and enter "auto evaporator cleaner" without the quotes, lots of kits less than Toyota.
  12. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I bought mine from Toyota dealership, costed 20$
  13. orenji
    orenji Senior Member
    5,884
    3,486
    I run mine A/C almost every day, every month of the year (California) and never have had any smell from my vents. Is it the lack of use that cause bad smells?
  14. qdllc
    qdllc Senior Member
    1,370
    399
    Generally, yes.
    If an AC goes unused, things can get in that block things up. I suppose it could happen with AC use, but it would have to happen quick.
    Most AC stench I notice (both auto and home) comes from those "transient" periods where it's not hot or cold enough to use AC/heat. Then, when you kick it in, you get that stench from all the stuff that lingered in the vents during that time.
    Also, mold and mildew have a hard time growing when the air is constantly moving. If you don't need AC/heat, it helps to keep the fan running so fresh air is constantly circulating.
  15. Tande
    Tande Active Member
    502
    302
    Mich.
    Could/Be.......constant AC use = constant condensate drainage/flushing........FWIW
  16. Mendel Leisk
    38,644
    We use AC only infrequently, and I'm no noticing any smell. Main use is dehumidifying when it's raining. AC can run (unasked) when you set mode to Heat/Defog.
    I think if you NEVER used AC there'd be no mildew issues. AC use invariably causes water vapour to condensate on its "radiator" in the the HV system. If this water does not get a chance to dry out you get mold.
    #16 Mendel Leisk, Apr 6, 2015
  17. frodoz737
    4,297
    2,348
    33
    Regardless why...if it stinks clean it. Many thanks to A617 and NutzAboutBolts.
    NutzAboutBolts likes this.
  18. WA///M
    WA///M New Member
    Chicago, IL
    Excellent write up. Thank you.
  19. Former Member 68813
    3,524
    981
    US
    i searched the part number and they sell for about $15. cheaper than some comparable aftermarket products. many thanks to the OP.
  20. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I want to perform this on my 2011 Prius, but am having a hard time finding the cleaning kit for even $20. I called multiple dealers around my area and they all want $40... is there anywhere I can find it for cheap instead? I can't even find these on eBay...
