Even brand new 12V batteries are not
Discussion in 'Gen 2 Prius Technical Discussion' started by terramir, Feb 8, 2022.
Tags:
  1. terramir
    terramir Member
    305
    47
    Los Angeles
    My 12V Battery a warranty replacement is not charged properly by my Prius, from what I understand the Prius 12V battery is charged anytime the car is ready through the inverter from the main battery but when turn the car off and then to on it shows 11.8V in the display and 14.1V when the engine is on.
    Does anyone know why this is happening it should be charging at around 13.8V for standby use which is really what this battery is used for.
    And after charging for a while it should end up at 12.8 with a light load. But it seems every battery I put in this thing keeps dying on me eventually because it seems to be continually under charged.
    Thinking about rigging up one of those battery maintainer solar panels but that means wiring a cigarette lighter jack directly to the battery.
    And putting a over charge prevention circuit in the solar panel cable.
    what you guys think
    terramir
    ydpplqbd likes this.
    48,945
    prius is a poor charger, more of a maintainer. try charging it up, then see what she holds at.
  3. PriusCamper
    PriusCamper Senior Member
    10,897
    4,418
    Pacific Northwest, USA
    First step to replacing a battery is making sure the new one is fully charged. Not just trickle charged, but fully charged with a real charger! Seems like this did not happen for you?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    What's your usage pattern like ?
    In addition to never being fully charged, your new battery might be defective.
    How are you getting a warranty battery on an 18 year old car ??
    Except for that 11.8, your numbers look about right.....or at least acceptable.
  5. terramir
    terramir Member
    305
    47
    Los Angeles
    Warranty on the battery I purchased in 2019 full 4 year warranty :) not some prorated crap
    terramir
  6. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Have you ever drained the battery in the three years since installation. If it was fully discharged for any period of time, The lead plates have sulfide crystals and the battery is no longer fully capable. A good battery maintainer may be able to break up the sulfide crystals and restore the battery to usefulness.
    JeffD
  7. terramir
    terramir Member
    305
    47
    Los Angeles
    No this one was installed in 2021 the other one died in 2020 during the lockdowns, but it did go down to 8.3 V at one time for like a few weeks till I replaced the coils. then I drove about 60 miles. And it was up to 12.4 but the problem is unless I drive a ton just turning the car on for 30 minutes is not enough to charge the battery.
    Seems like the inverter doesn't output as much unless it's driven. Which doesn't make sense at all cause the power from the main traction battery should be sufficient to charge the battery.
    terramir
  8. jdenenberg
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    No, the inverter is always on at a slow charging status whenever your Prius in in "Ready" mode. It takes a long time to fully charge a depleted battery with a constant voltage charging system like the Prius. Once you left the battery depleted for a "few weeks" your battery was toast.
    JeffD
  9. rjparker
    rjparker Tu Humilde Sirviente
    7,566
    4,437
    Texas Hill Country
    An agm battery can be charged at 14.9 vdc if needed. The higher the charge voltage the higher the amps going into the battery. 14.1 vdc charge voltage means the battery needs more charge; 13.8 vdc charge voltage means it is close to fully charged. On my car, 13.4 vdc while driving (not Park) is full. So your battery is not fully charged if all you see is 14.1 or higher in Ready and driving.
    1. If you garage your car or have a nearby ac outlet, a four stage battery maintainer like a Battery Tender Jr ($29) is a good idea for a vehicle that is not used much. This model comes with a hardwired cable to your battery or front jump point and a quick connect where you don't have to open the hatch or hood to use.
    https://bit.ly/BatteryTenderJrWalmart
    But there are other possible issues the informed owner should check.
    2. One is the battery is no longer as good as it was new. Load check it at an autosupply.
    3. Realize all modern cars drain the battery anytime they are off. Parasitic draws of 15 ma to 30 ma are reasonable with a Prius. Often aftermarket accessories or devices plugged into the ODB2 connector draw 50 ma - 1000 ma continuously even when "off". Occasionally lights are on somewhere, such as the hatch light. Sometimes standard modules causes excessive off state draw.
    Any excessive draw over 30 ma will quickly reduce the 12v batteries stored charge. A map light can discharge a battery to 10 v overnight, smaller parasitic draws could easily discharge your battery to 11.8v overnight. What is your car's parasitic draw?
    4. Keyfobs left next to the car sometimes cause higher than desired discharges for the first four hours.
    #9 rjparker, Feb 9, 2022
  10. sam spade 2
    7,035
    2,782
    2017 Prius c
    What he said.
    No mystery here.
    The onboard system was not designed to completely recharge a dead battery.
    That's what a battery charger is for. ;)
  11. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    I would check the connections, including the ground strap to the body, then not worry about it as the 12v battery is under warranty.
    Either the prius is "OFF" or "READY", anything else is asking for trouble.
    How many hours per week are you currently driving?
  12. terramir
    terramir Member
    305
    47
    Los Angeles
    Not driving much, as for map lights I replaced all the bulbs with led's so there not gonna drain the battery, I make a point of going out and running the car at least twice a week now, but it looks like I'm going to have to wire that socket up and plug the solar panel in it should fully charge the battery in about three-four days (I built the panel myself it can provide about .8A of power) which should fully charge the battery. I can't find the receipt anymore and the pepboys I bought it at closed so I do not know about warranty now.
    the Prius is ready, when I go down to charge it (street parking so a plug in battery tender is not an option).
  13. rjparker
    7,566
    4,437
    Texas Hill Country
    0.8 amp of 12v power is not enough to charge although it might accommodate a normal parasitic draw. Excessive parasitic draws come from many sources, we have seen things like the power steering module draw 900 ma continuously. 0.8 amp is 800 ma of peak power which is not continuous, eg you get no power at night or on overcast days. So measuring parasitic draw is the way to go. Having the battery load check is essential, if it is weak no amount of charging will help.
