Evers signal Prius 2016
Discussion in 'Gen 4 Prius Audio and Electronics' started by Leksvndr, Jun 17, 2022.
  1. Leksvndr
    Leksvndr Junior Member
    Hello, sorry in advance maybe i'm creating a similar question, but i didn't find the answer. I need to connect signal wire to my camera.
    New android stereo has a wire
    how can i connect?
    Thank you
    Prius 2016 and original stereo 86140-47270
    49,371
    what is an Evers signal?
  3. Leksvndr
    R is missing, gotta fix it.
    New stereo has a wire to connect it to the revers signal. So when I turn revers, back camera supposed turn on.
  4. bobthejedi
    bobthejedi Active Member
    137
    153
    SF Bay Area
    Just went through this on my 2016 prius 3, going to post lengthier document, but assuming that you have stepped down the voltage to your OEM camera from 12v to 6v already, that wire from the head unit should go do the green purple one on the harness on the steering wheel control harness, it should be the signal wire that the car sends to the head unit that its in reverse IMG-3662.jpg
    Note: its should be obvious when you look at it, but this is the top row (with clip facing up)
    Steering wheel harness with the reverse signal
    reverse camera harness with stepdown from 12v to 6v (12v white cables goes to ACC 12v)
