everything resets and/or won't lock or unlock and/or start
Discussion in 'Gen 2 Prius Technical Discussion' started by mamaj, Apr 11, 2009.
  1. mamaj
    mamaj New Member
    :confused: just bought 2005 prius hatchback with smart key function. i am consistently having issues with car locking and/or unlocking. also, car won't start. in addition, everyday, the clock and odometor reset over and over again on their own. i have to have this fixed because i am using the car in my business which requires my keeping records throughout the day on time & mileage. i need help in knowing what to do.....thanks for any responses and suggestions.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It sounds like your 12v battery is becoming disconnected. Do you have any kind of battery minder connected?
  3. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    The 12V battery is probably worn out. It is only used to start up the computers and operate electronics such as the key system and odometer while the car is stopped. As long as there is enough power to get things started, everything works normally once the car is running. But while it's off, a weak 12V battery causes all sorts of weird electronic problems.
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    That does have the classic symptoms of a failing 12 vdc auxiliary battery, especially given the age
    There are a few threads here on 12 vdc battery replacement, either the dealership one (No readily available aftermarket battery), or a conversion kit from elearnaid that uses a Mazda Miata Optima battery
  5. richard schumacher
    7,663
    1,038
    United States
