Evidence of previous maintenance?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sterlingarcher6969, Aug 5, 2022.
  1. Sterlingarcher6969
    Sterlingarcher6969 Junior Member
    64
    22
    Hi everyone this evening I was going to preform a transaxle fluid swap on my 2014 when I saw these blue marks. Are these from factory? They are on both drain and fill plugs.
  2. Tombukt2
    Tombukt2 Senior Member
    13,374
    2,405
    Durham NC
    I think so my Gen 2 has pink marks all over the transaxle like that
  3. Mendel Leisk
    41,884
    Probably marked after torquing at factory. There's some transaxle fluid change tips in my sig btw.
  4. Sterlingarcher6969
    64
    22
    Cool thanks guys. My genius self bought a set of hex sockets for the change but none of the 8 sizes were the one I needed
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    IIRC, it's 10 mm.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,494
    Taylors, SC
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Don't forget, when changing your transaxle fluid, ALWAYS remove the fill bolt first.
    That way you won't be in a situation where you have dumped your transaxle fluid and cannot remove the fill bolt, leaving you stuck with an undriveable car.
    jerrymildred likes this.
  8. Sterlingarcher6969
    64
    22
    Well I got my answer. The fluid was pitch black when I drained it yesterday. Full of the good stuff now. (ATF WS)
    jerrymildred and Mendel Leisk like this.
  9. Mendel Leisk
    41,884
    How many miles on it?
    For reference, Repair Manual drain-and-fill instruction attached:
    Raygon likes this.
  10. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    You cal always flip the car upside down and refill using the drain hole.
  11. Mendel Leisk
    41,884
    Add to your quote gallery? ;)
