exactly how far do you
Discussion in 'Prius c Fuel Economy' started by dolfanpete, Sep 16, 2012.
  1. dolfanpete
    dolfanpete Junior Member
    60
    Naples, Florida
    go before filling up? like is it ok to take it to the last notch? or do you do it at 2? i ask because i filled up for the first time saturday but i was at 4 notches left. i jumped the gun a bit i think
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    I try to fill up at 2 notches and that is probably early, but I like to play it safe.
    RocMills likes this.
  3. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Yesterday I filled up a few km after the last bar chime, 30.6 of a 36 L tank, with 784 km driven.
    The trip meter said 3.8 L/100 km so I had calculated 29.8 L used. I guess the internal fuel counter didn't agree completely with the pump. Nonetheless it suggests I had 138 km left before running on fumes. Perhaps if I'm adventurous some time, I'll drive until the trip meter suggests 33 L have been used.
    Galaxy Nexus ? 2
  4. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    I try to not go below three segments mainly because it is easier on the fuel pump which is located in the fuel tank. The fuel is used as a pump coolant, did you know that?
    ChinchillaGirl likes this.
  5. dolfanpete
    60
    Naples, Florida
    No I didn't.
  6. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    I don't fill the tank anymore. Gas weights a fair amount and I don't really need to carry around extra lb. it's something liken like 6lb per gallon so a full tank is like 60 lb. That's like a dozen bricks or a kid. And how wants to drive with a extra kid in the car.
    I put gas in basically as soon as it beeps at me and then put 5 gallons in.
  7. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    Filling the tank is a pia so I just go for the gusto and pump it full!
    Tracy likes this.
  8. dolfanpete
    60
    Naples, Florida
    i took it to the last notch, and then it started blinking and then i immediately filled it up. i got 412 miles on that tank. ( i went on a trip across the state on the highway going 60-70 mph)...i dont think that was too great. today i filled up and still had 2 notches left and had gone 417 miles...with two notches left!...so from now on i will take it to the last notch.
  9. Revan86
    286
    84
    High speeds like that will kill your mpgs in any car but Especially in a hatch back. Even this one lol
  10. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Just fill it up when you feel like it. I fill up about every other week or so. Usually around half a tank or a little lower.
    I don't feel a need to see how many miles I can get with a tank. I try really hard to keep drama at bay. After the teenage daughter and all her friends, my quota for drama has been filled.
    brucepmiller and Tracy like this.
  11. Tracy
    Tracy Member
    171
    101
    LOL!
    I tend to fill it on about the 3rd pip although in winter as a matter of policy, I usually keep at least a half tank in the car and fill it whenever we have a big storm on the horizon (not that often in Seattle). I don't have a fireplace and I've been through some extended power outtages so the car is sort of a back-up if I need to plug the phone in for a call or need a break from shivering (fortunately, I have neighbors with fireplaces ;-) I've also lived through some big earthquakes and I guess it's just part of my "emergency preparedness" mindset to try to avoid situations where I could be stranded if there is a factor that is in my control to manage.
  12. mjHession
    mjHession New Member
    43
    How do you track fuel with Fuelly if your not filling?
  13. goddess prii
    goddess prii Member
    63
    50
    Atlanta, GA burbs
    I fill up with 2 notches left. This may sound conservative but I don't want to run out of gas. In my old car( sebring) 1/4 of a tank was my fill up.
  14. Revan86
    286
    84
    I did not really want to make a longer post of it. What I do is when I need gas I take the 5gal gas can I had for ages and fill it when I get gas. Then top off the tank later on. It's a bit of a pain but like you said I can't really use fully if I only get a few gal at a time. I've not had the car long and refueling is not something a have to do all the time so it's not so bad. I'm sure after a while I won't even keep up with any of it. The car seems to be pretty right on with its numbers up to this point.
